Cisco 1142 AP as WGB
dominikhug
I'm trying to connect a full-IOS Cisco 1142 access point as WGB to our WLAN infrastructure.
I have these settings configured on our WLC:
There is a Win2k8 R2 NPS (Network Policy Server) RADIUS server in the background for handling the authentications against the active directory. I can see passed authentication in the event log.
The WGB is configured like this:
version 12.4
no service pad
service password-encryption
hostname ap
logging rate-limit console 9
enable secret 5 $1$YnK.$37j/OyuZDBr4DSnAEHWFT1
no aaa new-model
dot11 syslog
dot11 ssid InternalSSID
   authentication open eap eap_methods
   authentication network-eap eap_methods
   authentication key-management cckm
   dot1x credentials ADCred
   dot1x eap profile EAPProfile
   infrastructure-ssid
method mschapv2
username ADUsername
password ADPassword
username Cisco password 7 01300F175804
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid InternalSSID
antenna gain 0
station-role workgroup-bridge
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
I'm able to get a association to an AP but I'm not able to authenticate.
ap#sh dot11 associations all-client
Address           : 0026.994f.xxxx     Name             : APName
IP Address        : xx.xx.xx.xx.       Interface        : Dot11Radio 1
Device            : LWAPP-Parent      Software Version : NONE
CCX Version       : 5                  Client MFP       : On
State             : EAP-Assoc          Parent           : -
SSID              : InternalSSID
VLAN              : 0
Hops to Infra     : 0                  Association Id   : 1
Tunnel Address    : 0.0.0.0
Key Mgmt type     : CCKM               Encryption       : AES-CCMP
Current Rate      : m15.               Capability       : WMM
Supported Rates   : 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
Voice Rates       : disabled           Bandwidth        : 40 MHz
Signal Strength   : -54  dBm           Connected for    : 0 seconds
Signal to Noise   : 45  dB            Activity Timeout : 15 seconds
Power-save        : Off                Last Activity    : 0 seconds ago
Apsd DE AC(s)     : NONE
Packets Input     : 2287               Packets Output   : 225
Bytes Input       : 553482             Bytes Output     : 26055
Duplicates Rcvd   : 45                 Data Retries     : 0
Decrypt Failed    : 0                  RTS Retries      : 0
MIC Failed        : 0                  MIC Missing      : 0
Packets Redirected: 0                  Redirect Filtered: 0
Protocol                    Status            Auth     Port     WGB
Can somebody help me? Do I have to post more information?
Thank you!
13 Replies 13
Scott Fella
Have you looked at this doc?
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080905cea.shtml
-Scott
Hi Scott
I read different documents including the one you mentioned.
I used this doc for configuring because is uses exactly the same methods I use:
WGB Roaming: Internal details and Configuration
https://supportforums.cisco.com/docs/DOC-14944
Scott Fella
Well as a WGB, you would connect that to a single SSID and everything should pass right through. So all you need us for the WGB to associate to your WLAN SSID.
Simple sample config
http://www.cisco.com/en/US/docs/wireless/controller/7.0MR1/configuration/guide/cg_lwap.html#wp1895378
-Scott
I've added guest-mode because this is the only difference between the sample config and my config but it still doesn't work.
On console I can see this message:
%DOT11-4-CANT_ASSOC: Interface Dot11Radio1, cannot associate: Too many retries
And I think the WGB ist flapping between different reachable APs propagating the same SSID. Is it possible to change this behaviour?
I believe in the WGB you can define the AP you want to associate to.
Scott Fella
Sent from my iPhone
-Scott
Scott Fella
Make sure you have passive mode enabled on the WLAN SSID. I believe this was supported on the 7.x.
You can run a debug on the wlc also to see if you see anything.
-Scott
We're using Cisco WiSMv1. Passive mode is only available on 5500 and 2100 I think.
I was able to tie the WGB to only one AP but it still doesn't work.
I've found a new log-message on WLC:
*dot1xMsgTask: Dec 20 10:16:02.230: %DOT1X-3-MAX_EAPOL_KEY_RETRANS: 1x_ptsm.c:444 Max EAPOL-key M1 retransmissions exceeded for client 44:d3:ca:62:91:8e
I've attached the output of 'debug client 44d3.ca62.918e' from WLC. Maybe you can see something.
Could it be also RADIUS-server related?
If its radius related, you would see a failed authentication on the wlc and on the log in the radius you would see the same.
I see you posted on the other forum and tried wpa and that failed. Try to sart from basic and use an open connection an get that to work first. The had part that you will face is the WGB authenticating 802.1x. So start with the basic and get that working first.
-Scott
I recently sent an hour t/s a wgb and my issue was that I didn't have aironet extensions enabled on the wlc/WLAN. Is yours enabled?
Scott Fella
So that Mac address is the WGB or a wired client?
-Scott
It's from the WBG D1 interface:
ap#sh int d1
Dot11Radio1 is up, line protocol is up
  Hardware is 802.11N 5GHz Radio, address is 44d3.ca62.918e (bia 64ae.0c5c.5be0)
  MTU 1500 bytes, BW 54000 Kbit/sec, DLY 1000 usec,
  Last input never, output 00:00:00, output hang never
  Input queue: 0/1677/3/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/30 (size/max)
  5 minute input rate 1000 bits/sec, 1 packets/sec
  5 minute output rate 2000 bits/sec, 3 packets/sec
     2953 packets input, 540325 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     6319 packets output, 558439 bytes, 0 underruns
     144 output errors, 0 collisions, 6 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
ap#
I made some additional attempts to get it working but I failed. So i changed the security settings to WPA-PSK to check if using a WGB ist the right way. Now I'm testing.
Thanks for your help and merry christmas.
Dominik
