10-27-2017 12:40 AM - edited 07-05-2021 07:46 AM
Hello
I am using 10 number access points 1702i Autonomous AP IOS Software-15.3.3-JF1(ED),
ISP broad band is 100 mbps when i was connected to ap it is show 15 to 20 mbps and when was connected LAN speed is 90 to 98 mbps
cloud any one help us regarding this problem i am going on trying not able to find solution
10-27-2017 04:24 AM
1. Are you using WPA2 with AES
2. WMM is enabled or not ?
can you paste the config of the AP.
Dont forget to rate helpful posts
10-27-2017 10:51 AM
10-27-2017 10:59 AM
