06-15-2020 02:48 AM - edited 07-05-2021 12:10 PM
Hi All,
I just upgraded a Cisco 3504 from version 8.5.140.0 to 8.5.161.0. Just as normal routine, but something strange happens:
After the upgrade version 8.5.161.0 turn into version 8.7.106.0.
Sounds weird,but luckely i have the logs:
******Check this: The primary is version 8.5.140 and backup 8.5.135.0
(Cisco Controller) >show ap image all
Total number of APs.............................. 2
Number of APs
Initiated....................................... 0
Downloading..................................... 0
Predownloading.................................. 0
Completed predownloading........................ 0
Not Supported................................... 0
Failed to Predownload........................... 0
Predownload Predownload Flexconnect
AP Name Primary Image Backup Image Status Version Next Retry Time Retry Count Predownload
AP_1E 8.5.140.0 8.5.135.0 None None NA NA
AP_BG 8.5.140.0 8.5.135.0 None None NA NA
*****After uploading version 8.5.161.0 into the controller i did a predownloading to the APs:--- so far the version is still 8.5.161.0 ( downloaded the file today with size 296 MB).
Number of APs
Predownloading.................................. 2
AP_1E 8.5.140.0 8.5.135.0 Predownloading 8.5.161.0 NA 0
AP_BG 8.5.140.0 8.5.135.0 Predownloading 8.5.161.0 NA 0
*****The predownloading is ready and as you can see the backupimage is now 8.5.161.0 and ready to swap:
Number of APs
Completed predownloading........................ 2
AP_1E 8.5.140.0 8.5.161.0 Complete 8.5.161.0 NA NA
AP_BG 8.5.140.0 8.5.161.0 Complete 8.5.161.0 NA NA
*****After the swap the primary image is now 8.5.161.0 as expected.
Number of APs
AP_1E 8.5.161.0 8.5.140.0 Complete 8.5.161.0 NA NA
AP_BG 8.5.161.0 8.5.140.0 Complete 8.5.161.0 NA NA
****After the reboot of the 3504 controller the image is now 8.7.106!
Number of APs
AP_BG 8.7.106.0 8.5.140.0 None None NA NA
AP_1E 8.7.106.0 8.5.140.0 None None NA NA
I have no problems with this release, but i can imagine that the "version swap" could lead to some misunderstanding when having issue's and need some TAC advice.
Solved! Go to Solution.
06-15-2020 06:33 AM
Hi rafafilho11,
It seems that 8.7.106.0 is the default and the active image.
According to the documents: after upgrade the WLC automaticaly upgrade, the new image would become active and the previous image (8.5.140) would become the backup image.
To explain the experienced behavior: There is just a important detail: it depends of which image is default and active.
I think 8.7.106 was previous the primary image, but not active. The 8.5.140.0 was actualy the backup image and active as boot.
After upgrading to version 8.5.161 this update became indeed the primary and the previous 8.7.106.0 version the backup image as writen in the Cisco manuals. But the previous backup image setting kept default and active and loading the new backup image 8.7.106.0.
I already made the primary boot active now and works fine with 8.5.161.0.
Lessons learned: dont trust the gui about the primary version, check first cli boot to be sure.
Thanks for mentioning the boot status.
(Cisco Controller) >show boot
Primary Boot Image............................... 8.5.161.0
Backup Boot Image................................ 8.7.106.0 (default) (active)
(Cisco Controller) >show sys?
sysinfo syslog system
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.7.106.0
RTOS Version..................................... 8.7.106.0
Bootloader Version............................... 8.5.103.0
Emergency Image Version.......................... 8.5.103.0
OUI File Last Update Time........................ N/A
Build Type....................................... DATA + WPS
System Name...................................... WLC
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.2427
Redundancy Mode.................................. Disabled
IP Address....................................... 172.16.1.12
IPv6 Address..................................... ::
Last Reset....................................... Soft reset due to RST_SOFT_RST write
System Up Time................................... 0 days 3 hrs 50 mins 27 secs
System Timezone Location......................... (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
System Stats Realtime Interval................... 5
--More-- or (q)uit
System Stats Normal Interval..................... 180
Configured Country............................... NL - Netherlands
Operating Environment............................ Commercial (10 to 35 C)
Internal Temp Alarm Limits....................... -10 to 80 C
Internal Temperature............................. +64 C
Mgig Temp Alarm Limits........................... -10 to 78 C
Mgig Temperature................................. +55 C
External Temp Alarm Limits....................... -10 to 71 C
External Temperature............................. +48 C
Fan Status....................................... OK
Fan Speed Mode................................... Disable
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 3
Number of Active Clients......................... 6
OUI Classification Failure Count................. 1
Burned-in MAC Address............................ 6C:DD:30:4B:28:00
Maximum number of APs supported.................. 150
System Nas-Id....................................
--More-- or (q)uit
WLC MIC Certificate Types........................ SHA1/SHA2
Licensing Type................................... RTU
06-15-2020 04:38 AM
What the commands below are showing:
show boot
show sysinfo
06-15-2020 06:33 AM
Hi rafafilho11,
--More-- or (q)uit
--More-- or (q)uit
06-15-2020 08:05 AM
06-16-2020 03:07 AM
Hi rrudling,
Thanks for mentioning. I've seen those issues too and luckely for me the site did not have hundreds of APs ;-)
