Beginner
Cisco 3650 - Converged Wireless Access - Denali 16.3.5 - AIR-AP2802I-E-K9
Can somebody tell me if AIR-AP2802I-E-K9 supported by Denali 16.3.5? I can't make it register. It receives 2 IP addresses from the DHCP pool. When I look at the traces I see the following messages:
-- this is unknown address: srcAddr=34.178.84.10 (the AP was just received from Cisco)
2017/10/20 11:30:55.577 [capwap]: [7213]: UUID: 0, ra: 0 (debug): apCheckApModelSupported Model- AIR-AP2802I-E-K9 not found
2017/10/20 11:30:55.577 [capwap]: [7213]: UUID: 0, ra: 0 (debug): apCheckApModelSupported Check Model- AIR-AP2802I-E-K9
2017/10/20 11:30:55.576 [capwap]: [7213]: UUID: 0, ra: 0 (info): 7070.8bcf.5fe0 Join Priority Processing status = 0, Incoming Ap's Priority 0, MaxLrads = 100, joined Aps =0
2017/10/20 11:30:55.576 [capwap]: [7213]: UUID: 0, ra: 0 (debug): 7070.8bcf.5fe0 Discovery request: Vendor payload type = 5, length = 22
2017/10/20 11:30:55.576 [capwap]: [7213]: UUID: 0, ra: 0 (debug): 7070.8bcf.5fe0 Discovery request: Vendor payload type = 207, length = 10
2017/10/20 11:30:55.576 [capwap]: [7213]: UUID: 0, ra: 0 (debug): 7070.8bcf.5fe0 Discovery Type = Static Config
2017/10/20 11:30:55.576 [capwap]: [7213]: UUID: 0, ra: 0 (debug): 7070.8bcf.5fe0 Discovery request: Total msgEleLen = 194
2017/10/20 11:30:55.576 [capwap]: [7213]: UUID: 0, ra: 0 (info): 7070.8bcf.5fe0 Primary Discovery Request from 10.84.178.34:5248
2017/10/20 11:30:55.576 [capwap]: [7213]: UUID: 0, ra: 0 (ERR): Unable to find the First RCB index. Return Value: 2
2017/10/20 11:30:55.576 [capwap]: [7213]: UUID: 0, ra: 0 (debug): Platform capability Check-single-AP-per-port is TRUE
2017/10/20 11:30:55.576 [capwap]: [7213]: UUID: 0, ra: 0 (debug): 7070.8bcf.5fe0 length = 4, packet received from 7070.8bcf.5fe0
2017/10/20 11:30:55.576 [capwap]: [7213]: UUID: 0, ra: 0 (info): 0000.0000.0000 Received capwap control message, 211 for ID 0x00000081
2017/10/20 11:30:55.576 [capwap]: [7257]: UUID: 0, ra: 0 (debug): Received CAPWAP Packet from(port =5248 srcAddr=34.178.84.10)
2017/10/20 11:30:21.423 [btrace]: [2514]: UUID: 0, ra: 0 (note): Single message size is greater than 1024
2017/10/20 11:30:21.417 [tdllib]: [2514]: UUID: 0, ra: 0 (note): NOT need to update epoch /tmp/tdlresolve/epoch_dir//2017_10_20_06_00_6736.epoch
2017/10/20 11:29:01.542 [capwap]: [7213]: UUID: 0, ra: 0 (info): 7070.8bcf.5fe0 Primary Discovery Response sent to 10.84.178.34:5248
2017/10/20 11:29:01.542 [capwap]: [7213]: UUID: 0, ra: 0 (debug): 7070.8bcf.5fe0 encodeLen = 107 len = 16
2017/10/20 11:29:01.542 [capwap]: [7213]: UUID: 0, ra: 0 (info): abcdefghijklmnopabcdefg encode mwarType = 0 in capwapMwarTypePayload.
2017/10/20 11:29:01.542 [capwap]: [7213]: UUID: 0, ra: 0 (info): Encode static AP manager 10.84.178.33, AP count 0
2017/10/20 11:29:01.542 [capwap]: [7213]: UUID: 0, ra: 0 (debug): 7070.8bcf.5fe0 msgLength = 36
2017/10/20 11:29:01.542 [capwap]: [7213]: UUID: 0, ra: 0 (info): 7070.8bcf.5fe0 Validated Discovery request with dest ip : 255.255.255.255 from AP 10.84.178.34. Response to be sent using ip : 10.84.178.33
2017/10/20 11:29:01.542 [capwap]: [7213]: UUID: 0, ra: 0 (debug): apCheckApModelSupported Model- AIR-AP2802I-E-K9 not found
2017/10/20 11:29:01.542 [capwap]: [7213]: UUID: 0, ra: 0 (debug): apCheckApModelSupported Check Model- AIR-AP2802I-E-K9
Thank you
1 ACCEPTED SOLUTION
Re: Cisco 3650 - Converged Wireless Access - Denali 16.3.5 - AIR-AP2802I-E-K9
it looks like the 2800 is in ME not in AP mode.
I see this info on AP logs:
Cisco Aironet 2800 Series Mobility Express
Welcome to the Cisco Wizard Configuration Tool
Use the '-' character to backup
Would you like to terminate autoinstall? [yes]:
can you double check. ("show version" from AP2800 will be better )
You can follow below link to convert to capwap AP. (section: Converting a Mobility Express AP into a CAPWAP AP)
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-3/b_Cisco_Mobility_Express_Deployment_Guide/b_Cisco_Mobility_Express_Deployment_Guide_chapter_010.html
Highlighted
Hall of Fame Guru
Converged Access (CA) is not supported beyond Cisco IOS XE Denali 16.3.x.
Beginner
Thanks. I am aware about that. But the version in use is 16.3.x
It is not supported in 16.5.x and 16.6.x
Hall of Fame Guru
It means starting from version 16.3.X (and later), Converge Access is not supported.
Another option is to load Converge Access to at AP that can support this feature.
Beginner
Leo, I don't want to argue but this is not mentioned in the release notes of 16.3.5 or I don't see it?
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/16-3/release_notes/ol-16-3-3650.html
Hall of Fame Guru
My initial statement is incorrect.
The final support for Converge Access is 16.3.X.
CONVERGE.pngThe "new" Converge Access will be supported by the 9300, 9400 & 9500 called "UADP 2.0".
Beginner
P.S. As well as per Cisco Aironet 2800 Series Access Points Data Sheet:
Supported wireless LAN controllers
  Cisco 2500 Series Wireless Controllers, Cisco Wireless Controller Module for ISR G2, Cisco Wireless Services Module 2 (WiSM2) for Catalyst® 6500 Series Switches, Cisco 5500 Series Wireless Controllers, Cisco Flex® 7500 Series Wireless Controllers, Cisco 8500 Series Wireless Controllers, Cisco Virtual Wireless Controller
  Cisco Catalyst 3850 Series Switches, Cisco Catalyst 3650 Series Switches
  Cisco Mobility Express
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-2800-series-access-points/datasheet-c78-736497.html
Please share
-- "show logging " from wlc
-- "AP console" output when it tries to join.
Beginner
Hi Vepannir,
I am attaching the output from the AP. There is noting in the log of the switch regarding the wireless negotiation. I have a trace of capwap negotiation part of which I have attached in the beginning.
3650#sh ver
Cisco IOS Software [Denali], Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 16.3.5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Thu 05-Oct-17 00:38 by mcpre
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 3.76, RELEASE SOFTWARE (P)
3650 uptime is 6 hours, 54 minutes
Uptime for this control processor is 6 hours, 57 minutes
System returned to ROM by reload
System restarted at 09:18:00 DST Fri Oct 20 2017
System image file is "flash:packages.conf"
Last reload reason: Reload Command
Technology Package License Information:
Technology-package                   Technology-package
Current             Type             Next reboot
ipservicesk9        Permanent        ipservicesk9
cisco WS-C3650-8X24UQ (MIPS) processor (revision A0) with 865070K/6147K bytes of memory.
Processor board ID FDO2110V0C3
3 Virtual Ethernet interfaces
32 Gigabit Ethernet interfaces
24 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
253984K bytes of Crash Files at crashinfo:.
253984K bytes of Crash Files at crashinfo-2:.
3431232K bytes of Flash at flash:.
3431232K bytes of Flash at flash-2:.
0K bytes of  at webui:.
Base Ethernet MAC Address          : f8:0b:cb:2e:91:00
Motherboard Assembly Number        : 73-100819-04
Motherboard Serial Number          : FDO21090UT6
Model Revision Number              : A0
Motherboard Revision Number        : A0
Model Number                       : WS-C3650-8X24UQ
System Serial Number               : FDO2110V0C3
Switch Ports Model              SW Version        SW Image              Mode
*    1 28    WS-C3650-8X24UQ    16.3.5            CAT3K_CAA-UNIVERSALK9 INSTALL
     2 28    WS-C3650-8X24UQ    16.3.5            CAT3K_CAA-UNIVERSALK9 INSTALL
Switch 02
Switch uptime                      : 6 hours, 57 minutes
Base Ethernet MAC Address          : f8:0b:cb:2e:b1:00
Motherboard Serial Number          : FDO21100T3D
System Serial Number               : FDO2110V0CT
Configuration register is 0x102
3650#sh license right-to-use
Slot#     License Name       Type    Count  Period left
    1       ipservices  permanent      N/A     Lifetime
    1          apcount       base        1     Lifetime
    1          apcount      adder        3     Lifetime
License Level on Reboot: ipservices
    2       ipservices  permanent      N/A     Lifetime
3650#sh wireless summary
Access Point Summary
               Total    Up    Down
802.11a/n          0     0       0
802.11b/g/n        0     0       0
All APs            0     0       0
Client Summary
Current Clients : 0
Excluded Clients: 0
Disabled Clients: 0
Beginner
I suppose you you are right. This is the show ver from the AP.
I will follow the conversion procedure and will update you.
Thank you for the note.
cisco AIR-AP2802I-E-K9 ARMv7 Processor rev 1 (v7l) with 1028384/380316K bytes of memory.
Processor board ID FGL2134A2SA
AP Running Image     : 8.4.100.0
Primary Boot Image   : 8.4.100.0
Backup Boot Image    : 0.0.0.0
AP Image type    : MOBILITY EXPRESS IMAGE
AP Configuration : MOBILITY EXPRESS CAPABLE
2 802.11 Radios
Radio Driver version : 9.0.5.5-W8964
Radio FW version : 9.1.8.1
Glad that we are able to isolate the problem..
--- Vengat
********* Please rate useful post***********
Beginner
Hello Vengat,
The AP has registered after the conversion.
Thank you.
Zdravko
Great ...
Ask the Expert- Webex Hybrid Services Solutions
