09-26-2018 09:02 AM - edited 07-05-2021 09:13 AM
Hello, i have Cisco 3702 AP. I found that can be possible convert AP into CAP.
I used commands from this: https://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/configuration/guides/consolidated/b_cg74_CONSOLIDATED/b_cg74_CONSOLIDATED_chapter_01101110.pdf.
Commands used:debug capwap console cli
archive download-sw /overwrite /reload tftp://~~~~.tar
AP image: ap3g2-k9w8-mx.153-3.JD4
WLC: 8.3.112.0
I have tried all packages which available for download on cisco.com to this AccessPoint. https://software.cisco.com/download/home/285029865/type/280775090/release/15.3.3-JI1?i=!pp
Main problem that my ap installing image, then reboots, then downloading something from controller and reboots again. And after all reboots AP stays on same image as before.
Also on first install it fails :"
Image version check passed
Not enough free space to download image first w/o extracting
deleting existing version(s)...
Deleting current version: flash:/ap3g2-k9w8-mx.153-3.JD4...
Set booting path to recovery image: 'flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx'...done.
Extracting files...
ap3g2-k9w8-mx.153-3.JI1/ (directory) 0 (bytes)OOO... [timed out]
ERROR: Problem extracting files from archive.
Download image failed, notify controller!!! From:8.3.112.0 to 8.8.100.0, FailureCode:3
archive download: takes 26 seconds" and on 2nd try install normally.
Also my AP UnPrimed and i don't see this point in mobile application. But in wlc i see point without problems.
I think im doing something wrong but i don't know what. Sorry for my stupidity but can somebody help me convert AP to CAP?
09-26-2018 09:13 AM
Not enough space is not uncommon to happen. Try to console into AP and delete some files.
-If I helped you somehow, please, rate it as useful.-
09-27-2018 12:50 AM
I have deleted useless files from ap. No error when im installing new image, but again when it installs and then reboots it loading with old autonomous image.
09-27-2018 01:42 AM
No problem if the image has been deleted, once again you can extract the same image file
09-26-2018 02:56 PM
This is the problem. The AP is unable to "contact" the location where the file is stored. Could be a firewall issue or the wrong IP address was entered.
09-27-2018 12:39 AM
I confirm that ap can download image from ftp or tftp. There's no problem with communication between AP and fileserver.
09-27-2018 12:53 AM
paste the sh version infor from AP:
09-27-2018 01:00 AM
Cisco IOS Software, C3700 Software (AP3G2-K9W8-M), Version 15.3(3)JD4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Fri 17-Mar-17 12:36 by prod_rel_team
ROM: Bootstrap program is C3700 boot loader
BOOTLDR: C3700 Boot Loader (AP3G2-BOOT-M) LoaderVersion 15.2(4)JB, RELEASE SOFTWARE (fc1)
~~~~ uptime is 12 minutes
System image file is "flash:/ap3g2-k9w8-mx.153-3.JD4/ap3g2-k9w8-xx.153-3.JD4"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-AP3702I-UXK9 (PowerPC) processor (revision A0) with 376814K/134656K bytes of memory.
Processor board ID FCW2016N9TG
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.3.112.0
Access Point Type: World Mode
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: ~~~~~
Part Number : 73-15243-01
PCB Serial Number : FOC20152UBG
Top Assembly Part Number : 068-100398-04
Top Assembly Serial Number : FCW2016N9TG
Top Revision Number : A0
Product/Model Number : AIR-AP3702I-UXK9
Configuration register is 0xF
09-27-2018 01:12 AM
AP has loaded with CAPWAP image.
