08-01-2011 11:34 AM - edited 07-03-2021 08:30 PM
4402's been running quite happily until recently.
I have 11 wlan's configured, but only 5 are enabled at this moment in time.
There are 26ap's connected to the 4402, a mixture of 1130's and 1142's.
The memory error in the subject is popping up quite frequenty.
Anybody seen this? No reference I can find on this forum or other Cisco.com.
*osapiReaper: Aug 01 14:35:07.004: %OSAPI-1-MEM_LEAK_LOW_ALARM: osapi_task.c:5105 Free System Memory went below 100MB
*osapiReaper: Aug 01 14:34:56.996: %OSAPI-1-MEM_LEAK_LOW_ALARM: osapi_task.c:5105 Free System Memory went below 100MB
*osapiReaper: Aug 01 14:34:46.988: %OSAPI-1-MEM_LEAK_LOW_ALARM: osapi_task.c:5105 Free System Memory went below 100MB
*osapiReaper: Aug 01 14:34:36.980: %OSAPI-1-MEM_LEAK_LOW_ALARM: osapi_task.c:5105 Free System Memory went below 100MB
*osapiReaper: Aug 01 14:34:26.972: %OSAPI-1-MEM_LEAK_LOW_ALARM: osapi_task.c:5105 Free System Memory went below 100MB
*osapiReaper: Aug 01 14:34:16.964: %OSAPI-1-MEM_LEAK_LOW_ALARM: osapi_task.c:5105 Free System Memory went below 100MB
*osapiReaper: Aug 01 14:34:06.956: %OSAPI-1-MEM_LEAK_LOW_ALARM: osapi_task.c:5105 Free System Memory went below 100MB
08-01-2011 05:35 PM
This is just a Alarm informative,
Now you can prevent this alarm to be shown, by configuring the threshold memory alarms on the 4400 WLC cli to be the default value as following:
config memory monitor leaks 10000 30000
after modifying the configuration, the alarm will not be shown again, and as you don't have impact on your network, so no issues.
Please monitor the issue and lemme know how this helps!!
Please dont forget to rate the usefull posts!!
Surendra
05-17-2012 07:03 AM
Hi Surenda,
I also have this problem.
However, when I put in the command:-
I get the following warning:-
core dump will not be transfered reliably if memory is less than 95MB
Please configure the minimum threshold above 95MB for coredump to happen
Should I be doing this in an Enterprise environment?
John Beckmann
