04-04-2019 12:27 PM - edited 07-05-2021 10:12 AM
Hi all
I have a Issue WLC 5508 , the memory is kept at 80%, while the CPU is at 1%.
8.5.131.0 code , with 90 AP
Question : How can I check what is draining the memory of the WLC?
thanks
Solved! Go to Solution.
07-08-2019 12:33 PM
finally, I restarted the WLC and solved the problem of high memory usage
thanks a lot
04-04-2019 12:51 PM
"show memory summary" command should give some indication
(WLC) >show memory ?
allocations Query Memory pool allocations
history Display system memory usage history statistics.
mbuf Display mbuf information.
monitor Display detailed memory monitor information.
pools Query Memory pool per task allocations
statistics Display system memory usage statistics.
summary Display system memory usage statistics.
Rasika
*** Pls rate all useful responses ***
04-05-2019 04:58 AM
04-05-2019 02:29 PM
04-05-2019 04:53 PM
Hi Leo
wlc>show memory mbuf summary
System Up Time................................... 224 days 23 hrs 41 mins 8 secs
Maximum number of Mbufs.......................... 4608
Number of Mbufs Free............................. 4592
Number of Mbufs In Use........................... 16
Top 10 Mbuf Usage:
802.11 Mgmt...................................... 65522
DOT1X............................................ 65479
Fast Path Control................................ 65244
BONJOUR.......................................... 64912
IPv6............................................. 1521
IAPP............................................. 109
802.11 Probe..................................... 1
CAPWAP........................................... 1
DHCP............................................. 1
CDP.............................................. 1
04-05-2019 08:43 PM
04-06-2019 07:10 AM
thanks Leo..
some other idea because so much memory is being used on WLC ..
04-06-2019 03:39 PM
04-07-2019 12:37 PM
04-08-2019 06:52 AM
04-08-2019 11:34 AM
04-08-2019 01:06 PM
04-09-2019 04:20 PM
thanks so much Patoberli
I'm going to request a maintenance window, to restart the controller.
for now ....., how can I know which processes are occupying memory? or is it not so trivial to find out?
thanks again
Javier Mancilla
04-09-2019 11:53 PM - edited 04-09-2019 11:57 PM
show memory summary
shows you the memory usage and the processes using it.
In my case:
(Cisco Controller) >show memory summary -------------------------- System Memory Summary ------------------------- System Name:wlc-5520-1 Primary SW Ver:8.5.140.0 Current Time:Wed Apr 10 08:52:02 2019 System UP Time:75 days 9 hrs 30 mins 0 secs NAME: "Chassis" , DESCR: "Cisco 5520 Wireless Controller" PID: AIR-CT5520-K9, VID: V01, SN: XXXXXX
Total System Memory.............................. (32380884 KB) 31621 MB Total System Free Memory......................... (29339956 KB) 28652 MB (90 %) Total Memory in Buffers.......................... (86580 KB) Total Memory in Cache............................ (327892 KB) 320 MB Total Active Memory.............................. (2527436 KB) 2468 MB Total InActive Memory............................ (334916 KB) 327 MB Total Memory in Anon Pages....................... (2447884 KB) 2390 MB Total Memory in Slab............................. (32812 KB) 32 MB Total Memory in Page Tables...................... (7816 KB) 7 MB Effective Free Memory............................ (29395064 KB) 28706 MB (90 %) WLC Peak Memory.................................. (6147056 KB) 6002 MB WLC Virtual Memory Size.......................... (5838768 KB) 5701 MB WLC Resident Memory.............................. (2350408 KB) 2295 MB WLC Data Segment Memory.......................... (5728420 KB) 5594 MB Total Heap Including Mapped Pages................ (1784002 KB) 1742 MB Total Memory in Pmalloc Pools.................... (1713789 KB) 1673 MB Total Used Memory in Pmalloc Pools............... (1614790 KB) 1576 MB --More-- or (q)uit Total Free Memory in Pmalloc Pools............... (73022 KB) 71 MB ------------------------- Pmalloc Pools Information -------------------- Index Pool-Size Chunks-In-Pool Chunks-In-Use Memory(Size/Used/Free)KB 0 16 283800 279261 33257 /33186 /70 1 64 160000 68442 26250 /20527 /5722 2 128 108700 42849 24627 /16395 /8231 3 256 21500 13476 7558 /5552 /2006 4 384 28000 3390 13343 /4115 /9228 5 512 63000 13943 37898 /13369 /24528 6 1024 152700 148505 168208 /164013 /4195 7 2048 10000 3727 21015 /8469 /12546 8 4096 26350 24726 108076 /101580 /6496 9 Raw-Pool 0 2421 1273311 /1273311 /0 ------------------------- MBUF Information ---------------------------- Maximum number of Mbufs.......................... 24576 Number of Mbufs Free............................. 24560 Number of Mbufs In Use........................... 16 (Cisco Controller) >
The thing with the WLC is, to free memory, you have to reboot it (I don't know of another way). While you are doing that, I suggest that you also right upgrade to 8.5.140.0, as that update fixes some critical SSO HA bugs. Unless you use AP702 models, then don't upgrade to that version.
See here for some more details: https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html#anc9
And here the release notes: http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn85mr4.html#resolved-caveats_85mr4
There were at least three memory leaks fixed: CSCuw22659, CSCvm00214, CSCvm78368
04-11-2019 05:29 AM
I'm going to restart the controller and see if the memory usage levels are maintained.
otherwise I will open a case to TAC
in my case
wlc >show memory summary
Primary SW Ver:8.5.131.0
NAME: "Chassis" , DESCR: "Cisco 5500 Series Wireless LAN Controller"
PID: AIR-CT5508-K9, VID: V04, S/N: xxxxx
Total System Memory.............................. (1002612 KB) 979 MB
Total System Free Memory......................... (27720 KB) 27 MB (2 %)
Total Memory in Buffers.......................... (5568 KB)
Total Memory in Cache............................ (151492 KB) 147 MB
Total Active Memory.............................. (876452 KB) 855 MB
Total InActive Memory............................ (33748 KB) 32 MB
Total Memory in Anon Pages....................... (753164 KB) 735 MB
Total Memory in Slab............................. (48276 KB) 47 MB
Total Memory in Page Tables...................... (3056 KB) 2 MB
Effective Free Memory............................ (31464 KB) 30 MB (3 %)
WLC Peak Memory.................................. (1298188 KB) 1267 MB
WLC Virtual Memory Size.......................... (1297224 KB) 1266 MB
WLC Resident Memory.............................. (799436 KB) 780 MB
WLC Data Segment Memory.......................... (1200112 KB) 1171 MB
Total Heap Including Mapped Pages................ (466820 KB) 455 MB
Total Memory in Pmalloc Pools.................... (616775 KB) 602 MB
Total Used Memory in Pmalloc Pools............... (599845 KB) 585 MB
--More or (q)uit current module or <ctrl-z> to abort
Total Free Memory in Pmalloc Pools............... (15279 KB) 14 MB
0 16 50000 40741 3320 /3175 /144
1 64 56600 50499 6411 /6030 /381
2 128 20000 17629 3515 /3219 /296
3 256 976700 976614 293773 /293751 /21
4 384 6000 964 2554 /666 /1888
5 512 27500 23009 15146 /12900 /2245
6 1024 6000 4694 6304 /4998 /1306
7 2048 5500 2369 11279 /5017 /6262
8 4096 1000 316 4050 /1314 /2736
9 Raw-Pool 0 374 270404 /270404 /0
