10-27-2017 07:37 AM - edited 07-05-2021 07:46 AM
I have an 1832i that I'd like to use on a WLC 5508. Is this possible? Do I need to change the IOS on the AP or is already provisioned to use either a WLC or the Mobility Express?
10-27-2017 07:54 AM
yes it is possible..
Run "show version" on CLI
If the show version CLI displays AP Image Type: MOBILITY EXPRESS IMAGE and AP Configuration: MOBILITY EXPRESS CAPABLE, it operates both as Controller and an Access Point. It participates in the Master Election process in case of a failover.
cisco AI R-AP1852E-UXK9 ARMv7 Processor rev 0 (v71) with 997184/525160K bytes of memory. Processor board ID RFDP2BCR021 AP Running Image : 8.1.121.0 Primary Boot Image : 8.1.121.0 Backup Boot Image : 8.1.106.33 AP Image type : MOBILITY EXPRESS IMAGE AP Configuration : MOBILITY EXPRESS CAPABLE 0 Gigabit Ethernet interfaces 0 802.11 Radios Radio FW version . 1401b63d12113073a3C08aa67f0c039c0 NSS FW version : NSS.AK.1.0.c4-0Z026-E_cust C-1.24160.1
If the show version CLI shows AP Image Type: MOBILITY EXPRESS IMAGE and AP Configuration: NOT MOBILITY EXPRESS CAPABLE, it operates only as access point and does not participate in the Master Election process in case of a failover.
cisco AI R-AP1852E-UXK9 ARMv7 Processor rev 0 (v7I) with 997184/726252K bytes of memory. Processor board ID RFDP2BCR021 AP Running Image : 8.1.121.0 Primary Boot Image : 8.1.121.0 Backup Boot Image : 8.1.106.33 AP Image type : MOBILITY EXPRESS IMAGE AP Configuration : NOT MOBILITY EXPRESS CAPABLE 2 Gigabit Ethernet interfaces 2 802.11 Radios Radio FW version : 1401b63d121b073a3008aa67f0c039d0 NSS FW version : NSS.AK.1.0.c4-00O26-E_cust C-1. 24160.1
Please follow below link to convert AP to ME:
************Please rate Usefull post **************
10-27-2017 08:14 AM
So based on your response and the output of the AP it looks like I can use it on a WLC 5508. Does it operate the same as the older models where it does a broadcast capwapp looking for a controller?
cisco AIR-AP1832I-B-K9 ARMv7 Processor rev 0 (v7l) with 966396/717400K bytes of memory.
Processor board ID KWC21180593
AP Running Image : 8.3.112.0
Primary Boot Image : 8.3.112.0
Backup Boot Image : 0.0.0.0
1 Gigabit Ethernet interfaces
2 802.11 Radios
Radio FW version : 2776931df5be64dcd1cbe2e7082a7079
NSS FW version : NSS.AK.1.0.c10-00017-E_custC-1.67978.1
10-27-2017 08:34 AM
I am Sorry..
Currently your AP1832 is running in ME mode. You have to convert that to AP so that it can join 5508.
10-27-2017 08:43 AM
you stated that if the show version shows this:
then I do not have to convert the image.
I'm confused.
10-27-2017 08:52 AM
I made a mistake in my first post.
Currently your 1832I running in mobility Express mode. 1832I wont join 5508 when it runs in Mobility Express mode.
If you want the AP1832 to join 5508, then you have to convert it to Capwap mode.
Follow below link and convert your 1832I to Capwap:
10-27-2017 09:05 AM
seems to be doing the broadcast now. I'll try on the network.
[*07/11/2017 00:10:39.9091] CAPWAP State: Discovery
[*07/11/2017 00:11:09.9397] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
10-27-2017 09:07 AM
Cool .. It should join the 5508..
Let us know how it goes.
10-27-2017 04:57 PM
Post the complete output to the following commands:
1. WLC: sh sysinfo;
2. WLC: sh time;
3. AP: sh version; and
4. AP: sh ip interface brief
Is DHCP Option 43 enabled?
