Beginner
Cisco AIR-AP2802I-E-K9 Failing to Join Controller
We are having an issue where our AP will not join any of our Wireless LAN controllers.
Console output shows;
[*01/18/2019 15:05:13.3086] CAPWAP State: Discovery
[*01/18/2019 15:05:13.3088] Got WLC address 172.16.1.5 from DHCP.
[*01/18/2019 15:05:13.3088] IP DNS query for CISCO-CAPWAP-CONTROLLER.ourdomain.com
[*01/18/2019 15:05:13.3124] Discovery Request sent to 172.16.1.5, discovery type DHCP(2)
[*01/18/2019 15:05:13.3126] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*01/18/2019 15:05:13.3137] Discovery Response from 172.16.1.3
[*01/18/2019 15:05:13.3137] Discovery response from MWAR ''running version 0.0.0.0 is rejected.
[*01/18/2019 15:05:13.3137] Failed to decode discovery response(status = 4).
[*01/18/2019 15:05:13.3137] CAPWAP SM handler: Failed to process message type 2 state 2.
[*01/18/2019 15:05:13.3138] Failed to handle capwap control message from controller - status 4
[*01/18/2019 15:05:13.3138] Failed to process unencrypted capwap packet 0x26fc000 from 172.16.1.3
[*01/18/2019 15:05:13.3138] Failed to send message to CAPWAP state machine, msgId 0
[*01/18/2019 15:05:13.3138] Failed to send capwap message 0 to the state machine. Packet already freed.
[*01/18/2019 15:05:13.3138] IPv4 wtpProcessPacketFromSocket returned 4
[*01/18/2019 15:05:13.3139] Discovery Response from 172.16.1.4
[*01/18/2019 15:05:13.3139] Discovery response from MWAR ''running version 0.0.0.0 is rejected.
[*01/18/2019 15:05:13.3139] Failed to decode discovery response(status = 4).
[*01/18/2019 15:05:13.3139] CAPWAP SM handler: Failed to process message type 2 state 2.
[*01/18/2019 15:05:13.3139] Failed to handle capwap control message from controller - status 4
[*01/18/2019 15:05:13.3139] Failed to process unencrypted capwap packet 0x26f6000 from 172.16.1.4
[*01/18/2019 15:05:13.3139] Failed to send message to CAPWAP state machine, msgId 0
[*01/18/2019 15:05:13.3140] Failed to send capwap message 0 to the state machine. Packet already freed.
[*01/18/2019 15:05:13.3140] IPv4 wtpProcessPacketFromSocket returned 4
From the log it looks like a version mismatch - https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
The compatibility matrix shows that version 8.2.110.0 is supported and the AP is running 8.5.135.0
cisco AIR-AP2802I-E-K9 ARMv7 Processor rev 1 (v7l) with 1028584/672912K bytes of memory.
Processor board ID XXX
AP Running Image : 8.5.135.0
Primary Boot Image : 8.5.135.0
Backup Boot Image : 8.3.143.0
2 Gigabit Ethernet interfaces
1 802.11 Radios
Radio Driver version : 9.0.5.5-W8964
Radio FW version : 9.1.8.1
NSS FW version : 2.4.24
Could somebody point me in the right direction?
13 REPLIES 13
Highlighted
Beginner
Re: Cisco AIR-AP2802I-E-K9 Failing to Join Controller
Hello callumlee,
What version are you running on the WLC?
2802E requers the WLC to run at minimum 8.2.110.0.
regards,
Jonas
**Don't forget to rate helpful posts**
Contributor
Looks like CSCvf71074, would recommend you to contact TAC.
-Rate helpful posts-
hello is this bug also apply for 2800 series access points?
Hall of Fame Community Legend
It applies to AP2800/AP3800.
VIP Mentor
pasthe the output of the command:
sh sysinfo from WLC
Post the complete output to the following commands:
1. WLC: sh sysinfo;
2. WLC: sh time
Initial output shows the AP has the wrong time and date. Make sure the WLC is configured with NTP.
Beginner
sh sysinfo from one of the WLC, the other is a 9800-CL which doesn't recognise the command.
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.5.135.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 2.2
OUI File Last Update Time........................ Sun Sep 07 10:44:07 IST 2014
Build Type....................................... DATA + WPS
System Name...................................... XXXXXX
System Location..................................
System Contact................................... Network Manager
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. Disabled
IP Address....................................... 172.16.1.3
IPv6 Address..................................... ::
Last Reset....................................... Software reset
System Up Time................................... 224 days 22 hrs 2 mins 37 secs
System Timezone Location......................... (GMT) London, Lisbon, Dublin, Edinburgh
--More or (q)uit current module or <ctrl-z> to abort
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... GB - United Kingdom
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +38 C
External Temperature............................. +22 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 11
Number of Active Clients......................... 434
OUI Classification Failure Count................. 0
Burned-in MAC Address............................ XXXXXXXX
Power Supply 1................................... Present, OK
Power Supply 2................................... Absent
Maximum number of APs supported.................. 500
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1
and sh time from the same controller;
Time............................................. Tue Jun 11 08:36:03 2019
Timezone delta................................... 0:0
Timezone location................................ (GMT) London, Lisbon, Dublin, Edinburgh
NTP Servers
NTP Version.................................. 3
NTP Polling Interval......................... 600
Index NTP Key Index NTP Server Status NTP Msg Auth Status
1 0 172.17.8.21 In Sync AUTH DISABLED
2 0 172.17.8.22 Not Synched AUTH DISABLED
The time is very far off on the AP, but is usually set by the controller.
Post the complete output to the command "sh capwap client rcb".
You may need to upgrade the firmware of the controller because I suspect this is CSCvf71074.
Beginner
It can't be CSCvf71074 because that is fixed in 8.5.110.0 and this WLC is running 8.5.135.0. But upgrading WLC code would address a number of other possible bugs. We've recently seen https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvk53499 which also prevents APs joining and despite what the notes say reloading the AP doesn't always help but it is fixed in latest MR candidate which you can get from https://community.cisco.com/t5/other-wireless-mobility-subjects/8-5-mr5-interim-build-availability/td-p/3832744
Beginner
That command is not recognised on the WLC for some reason, the AP is also failing to join our new 9800-CL which was built recently with the latest stable release, im guessing it is a problem with the AP or would the bug carry over?
Could we look further into the time mismatch, is setting the time manually possible? I tried to "clock set" command but it was not recognised.
VIP Advocate
Which version is running on the 9800-CL?
Please note, it first tries to contact 172.16.1.5 and afterwards 172.16.1.4, which is which WLC?
Beginner
version on the 9800-CL is 16.10.1e
9800-CL is the 1.5 IP
VIP Mentor
OK then you need to upgrade the AP software firs5t to : ap3g3-k9w8-tar.153-3.JI3.tar
9800 SW 16.10.1e is equivalent to AirOS 8.8.111.0 and then AP need minimum version of 15.3(3)JI3 to Joiun WLC.
Dont forget to rate helpful posts
Content for Community-Ad
August's Community Spotlight Awards
