Cisco AP 1130 cannot associate Wireless phone 7921
csocorro1
Good day,
I have a wireless phone 7921, trying to connect it to an autonomous AP 1131.
I tried configuring both WPA and WPA with TKIP and AES, and it does not associate, it is not even showing as an authentication failed, it seems that it is not even negotiating.
When I left the network opened, with no security, it associated without a problem.
Is there any special configuration needed or do you have any recommendation?
7 Replies 7
What version of software your running on it ? Pls share your config to have a look
Rasika
Thanks for your response Rasika,
Attached you can find the sh run.
The firmware version of the phone is 1.4.6.
Just as an additional note, we have other sites with the exact same configuration and it is currently working.
Thank you for your help!
Is it possible to make that Voice SSID to run WPAv2 & advertise only on 5GHz (radio 1, currently it is shutdown) to test ?
dot11 ssid <ssid_name>
authentication open
authentication key-management wpa version 2
interface Dot11Radio1
encryption vlan X mode ciphers aes-ccm
Rasika
*** Pls rate all useful responses ***
Hi Rasika,
I just tested and it has the same behaviour.
The AP is not even detecting the connection attempt of the phone.
johnd2310
Level 8
Level 8
What is your AP configuration for the SSID?
John
**Please rate posts you find helpful**
Hi John,
Attached the information.
Please don't post type 7 passwords in configurations, they can be reversed within a second! (In other words, I have your Wi-Fi password now and your Radius shared secret ).
