Cisco AP 1242 Up/Downgrade
josefbrey
Hi, how to download IOS-images for upgrading and downgrading 1242-AP from/to autonomous mode?
8 Replies 8
Roman Rodichev
Level 7
Level 7
IOS>LWAPP, you use cisco's upgrade tool
CiscoAironet-AP-to-LWAPP-Upgrade-Tool-v34.exe
LWAPP>IOS, from WLC's CLI you do:
"config ap tftp-downgrade "
it will automatically tftp the image and reboot the AP with the autonomous IOS image
Thanks for this information!
Regards, JB
When doing the downgrade from the controller, will the AP keep it's IP address and/or hostname?
It doesn't act like holding in the mode button does it? In other words, it will download with current IP address, not boot it into a 10.0.0.1 address and look for the default tar file?
Would they be able to be converted to IOS remotely without losing connection?
No it won't.
nutchaporn
IOS to LWAPP and LWAPP convert to IOS see link for complete guide :
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html
This link is ok. I have converted IOS to LWAPP for 20 APs <1242AG>. It works :-)
Don't forget to preconfigure your WLC too.
Yes, thanks!
But unfortunately it seems that I can't download the Images (probably because of my Guest-Level access?!).
Can this be performed on AP1231 APs? I have performed the upgrade to get this AP working with 5.2 code on a 4402 WLC. the upgrade is a success but then I get a certificate error? plus debug pm pki enable is no longer available!
Convert it again to LWAP and back to Autonomous using the Conversion Tool. During the conversion, make sure that the Autonomous AP and the conversion tool can ping the WLC's management IP Address.
