CISCO MSE web service port configuration
singhmanishp
I recently configured CISCO 3310 box with MSE version 7.2. Services are up and running in the box, I could add the MSE to WCS and also able to track the location using WCS. However, I could not connect the third party software to MSE web services to get the location information there. When I hit the server url "https://<my mse>" I get list of possible services like:
Error 404 - Not Found.
No service matched or handled this  request.
Known services are:
http://my server:8880/hs/
http://my server:8880/mdp/
http://my server:8880/admin/
http://my server:8880/wips/
http://my server:8880/location/
http://my server:8880/subscription/
http://my server:8880/aaa/
http://127.0.0.1:8180/localadmin/
https://127.0.0.1:8443/localadmin/
https://my server:8843/mdp/
https://my server:8843/wips/
https://my server:8843/hs/
https://my server:8843/admin/
https://my server:8843/location/
https://my server:8843/subscription/
https://my server:8843/aaa/
I browsed through the documentation (CAS_71.pdf) and found a text saying:
NotePort 80 will be enabled on the MSE if the enablehttp command was entered on MSE. Ports 8880 and 8843 will be closed on the MSE when the CA-issued certificates are installed on the MSE.
I am running the test system so I do not really want to install CA signed certificate, so I used self signed certificate and restarted the server, but it did not help.
Any pointer on how can I make the web services up and running on port 443 would be great!!
Cheers,
Manish
2 Accepted Solutions
Amjad Abdullah
Hi Manish,
what is the output of this command:
/etc/init.d/msed status
does it show you that your HTTPs is enabled or disabled?
Amjad
Rating useful replies is more useful than saying "Thank you"
Hi Manish,
Thank you for the answer. I wouldn't yet expect it to be a certificate issue though. Your answer is very helpful I guess for anyone face this problem
Please mark your prevoius post as the correct answer to better help people identify answered questions.
Amjad
21 Replies 21
Amjad Abdullah
Hi Manish,
Amjad
Hi Amjad,
Here is the output log:
STATUS:
Starting MSE Platform, Waiting to check the status.
MSE Platform is up, getting the status
Server Config
Product name: Cisco Mobility Service Engine
Version: 7.0.220.0
Hw Version: V01
Hw Product Identifier: XXXXXXXXXXX
Hw Serial Number: XXXXXXXXXXX
Use HTTP: false
Legacy HTTPS: false
Legacy Port: 8001
Log Modules: -1
Log Level: INFO
Days to keep events: 2
Session timeout in mins: 30
DB backup in days: 2
Services
Service Name: Context Aware Service
Service Version: 7.0.200.122
Admin Status: Enabled
Operation Status: Up
Service Name: Wireless Intrusion Protection Service
Service Version: 1.0.2079.0
Admin Status: Disabled
Operation Status: Down
Server Monitor
Server start time: Fri Jun 08 14:33:56 EEST 2012
Server current time: Sun Jun 10 00:42:51 EEST 2012
Server timezone: Europe/Helsinki
Server timezone offset: 7200000
Restarts: 1
Used Memory (bytes): 97782344
Allocated Memory (bytes): 146145280
Max Memory (bytes): 477233152
DB virtual memory (kbytes): 0
DB virtual memory limit (bytes): 0
DB disk memory (bytes): 1739966016
DB free size (kbytes): 0
Total Active Elements(Wireless Clients, Tags, Rogue APs, Rogue Clients, Interfer
ers, Wired Clients): 0
Active Wireless Clients: 0
Active Tags: 0
Active Rogue APs: 0
Active Rogue Clients: 0
Active Interferers: 0
Active Wired Clients: 0
Active Elements(Wireless Clients, Rogue APs, Rogue Clients, Interferers, Wired C
lients, Tags) Limit: 100
Active Sessions: 0
Wireless Clients Not Tracked due to the limiting: 233
Tags Not Tracked due to the limiting: 0
Rogue APs Not Tracked due to the limiting: 0
Rogue Clients Not Tracked due to the limiting: 0
Interferers Not Tracked due to the limiting: 0
Wired Clients Not Tracked due to the limiting: 0
Total Elements(Wireless Clients, Rogue APs, Rogue Clients, Interferers, Wired Cl
ients) Not Tracked due to the limiting: 233
Context Aware Sub Services
Subservice Name: Aeroscout Tag Engine
Subservice Name: Cisco Tag Engine
Manish
Hi Amjad,
I am able to run the webservices now!
The problem was with the installation of the certificates. My certificate validation was failing as I did not decrypt the private key before appending it to the certificate.
Here is the procedure to follow:
Generate the certificate signing request using the Certmgmt.sh.
Get the certificate signed
Decrypt the private key and append it to the signed certificate. I used .pem format,
Convert CA certificates (I got them in .der format) into .pem
using Certmgmt.sh:
Install CA certificates
Install server certiface
press option 10 (exit)
the msed reboots and now apache deamon is started.
Manish
Hi Manish,
Amjad
It seems i have the same problem: the Prime Infrastruture 1.2 cant reach the MSE 7.3.101.0 (WLC same version).
With scan port, I can see that my MSE is opened on port 8001 and SSH
  1. /etc/init.d/msed status
STATUS:
Health Monitor is running
MSE services are up, getting the status
Server Config
Version: 7.3.101.0
Health Monitor Ip Address: 1.1.1.1
High Availability Role: 1
Hw Version: V01
Hw Product Identifier: AIR-MSE-VA-K9
Hw Serial Number: S-CISCO-MSE-1.xxxxxxxxxx
Use HTTP: true
Legacy HTTPS: false
Legacy Port: 8001
Log Modules: -1
Log Level: INFO
Services
Service Version: 7.3.0.40
Service Version: 1.0.4038.0
Service Name: MSAP Service
Service Version: 1.1.0.38
Server Monitor
Server start time: Thu Oct 04 20:16:02 CEST 2012
Server current time: Thu Oct 04 20:19:30 CEST 2012
Server timezone: Europe/Paris
Server timezone offset: 3600000
Restarts: 2
Used Memory (bytes): 19686320
Allocated Memory (bytes): 160956416
DB disk memory (bytes): 1932920448
Active Sessions
Session ID: 32429
Session User ID: 2
Session IP Address: 10.2.199.2
Session start time: Thu Oct 04 20:16:36 CEST 2012
Session last access time: Thu Oct 04 20:18:35 CEST 2012
Total Active Elements(Wireless Clients, Tags, Rogue APs, Rogue Clients, Interferers, Wired
Clients): 0
Active Tags: 0
Active Rogue APs: 0
Active Elements(Wireless Clients, Rogue APs, Rogue Clients, Interferers, Wired Clients, Ta
gs) Limit: 100
Active Sessions: 1
Wireless Clients Not Tracked due to the limiting: 0
Total Elements(Wireless Clients, Rogue APs, Rogue Clients, Interferers, Wired Clients) Not
The enablehttp command in ssh doesn't solve the problem...
Thanks a lot if you have any idea.
Gérald.
These are the logs from the Prime Infrastruture:
10-05-2012          12:23:39          Local0.Error          10.2.199.2          10/05/12 12:23:40.333 ERROR [aesMse] [http-443-21] Error when trying to add Server Engine  S-CISCO-MSE-1
10-05-2012          12:23:39          Local0.Error          10.2.199.2          at java.lang.Thread.run(Unknown Source)
10-05-2012          12:23:39          Local0.Error          10.2.199.2          at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
10-05-2012          12:23:39          Local0.Error          10.2.199.2          at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
10-05-2012          12:23:39          Local0.Error          10.2.199.2          at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859)
10-05-2012          12:23:39          Local0.Error          10.2.199.2          at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
10-05-2012          12:23:39          Local0.Error          10.2.199.2          at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
10-05-2012          12:23:39          Local0.Error          10.2.199.2          at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:554)
10-05-2012          12:23:39          Local0.Error          10.2.199.2          at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
10-05-2012          12:23:39          Local0.Error          10.2.199.2          at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
10-05-2012          12:23:39          Local0.Error          10.2.199.2          at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
10-05-2012          12:23:39          Local0.Error          10.2.199.2          at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
10-05-2012          12:23:39          Local0.Error          10.2.199.2          at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
10-05-2012          12:23:39          Local0.Error          10.2.199.2          at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
10-05-2012          12:23:39          Local0.Error          10.2.199.2          at com.cisco.webui.common.LicenseFilter.doFilter(LicenseFilter.java:86)
10-05-2012          12:23:39          Local0.Error          10.2.199.2          at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:167)
10-05-2012          12:23:39          Local0.Error          10.2.199.2          at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:237)
10-05-2012          12:23:39          Local0.Error          10.2.199.2          at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:150)
10-05-2012          12:23:39          Local0.Error          10.2.199.2          at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:356)
10-05-2012          12:23:39          Local0.Error          10.2.199.2          at org.springframework.security.web.session.ConcurrentSessionFilter.doFilter(ConcurrentSessionFilter.java:108)
No logs on the MSE, except if I voluntary hit a wrong id/password:
10-05-2012          12:23:16          Kernel.Error          10.2.199.3          [Cisco MSE: CAS SE & Admin Module] - ERROR - Login failed for user admin
dears,
i have the same problem but i cannot solve it any ideas ??
Server Config
Version: 8.0.110.0
Hw Version: V01
Hw Serial Number: xxxxx
HTTPS: null
Legacy Port: 8001
Log Modules: -1
Log Level: INFO
Services
I am going through the same issue and even after several times restarting the msed service the https is not coming up. Need help on this.
Server Config
Version: 7.4.100.0
Hw Version: V01
Hw Serial Number: xxxx-mse.cisco.com
Use HTTP: false
Legacy HTTPS: false
Legacy Port: 8001
Log Modules: -1
Log Level: INFO
Services
Service Version: 7.4.0.38
Service Name: WIPS
Service Version: 1.0.4041.0
Service Name: Mobile Concierge Service
Service Version: 2.0.0.37
Service Name: Location Analytics Service
Service Version: 1.0.0.12
Server Monitor
Server start time: Fri Nov 29 17:45:07 UTC 2013
Server current time: Fri Nov 29 17:45:15 UTC 2013
Server timezone: Universal
Server timezone offset: 0
Restarts: 19
Used Memory (bytes): 76636608
Allocated Memory (bytes): 514523136
Max Memory (bytes): 1908932608
DB disk memory (bytes): 6211282560
Default Trap Destinations
Trap Destination - 1
IP Address: 10.105.1.90
Last Updated: Wed Mar 13 17:47:15 UTC 2013
Total Active Elements(Wireless Clients, Tags, Rogue APs, Rogue Clients, Interferers, Wired Clients): 0
Active Tags: 0
Active Rogue APs: 0
Active Elements(Wireless Clients, Rogue APs, Rogue Clients, Interferers, Wired Clients, Tags) Limit: 100
Active Sessions: 0
Total Elements(Wireless Clients, Rogue APs, Rogue Clients, Interferers, Wired Clients) Not Tracked due to the limiting: 0
[root@mse ~]#
Try to enable http by console or ssh on MSE typing:
root@mse ~]# enablehttp
after that try to connect MSE to Prime NCS.
Hi Oscar,
That didn't worked. I tried that option too but when I typed enablehttp and hit enter it doesn't gives any output and goes in kind of hanged state. I checked the /etc/init.d/msed status after that and its still the same as above.
Any other suggestion ?
Helllo,
Did you try to clear ip tables to re-open the ports ?
Clear iptables
Hi Gerald,
I cleared the iptables and then tried to check the status of msed  but it is still the same.
Other thing I want to know, Is it mandatory to get the https status as true before trying to add it on PI ?
[root@spwifi-mse ~]#
[root@spwifi-mse ~]# /etc/init.d/msed status
STATUS:
Server Config
Version: 7.4.100.0
Hw Version: V01
Hw Serial Number: spwifi-mse.cisco.com_a6379172-8b68-11e2-8e30-000c29761c2d
Use HTTP: false
Legacy HTTPS: false  ----------------------------<<<<<<<
Legacy Port: 8001
Log Modules: -1
Log Level: INFO
Https is not necessary but you can use it if http doesn’t work. I see http is down in your capture. In my case using "enablehttp" got http up and join it with Prime.
Anyway, does ping from MSE to Prime work?
Enable HTTP on MSE that runs version 6.0 software release
Enable HTTP on MSE that runs version 5.x software release
[root@mse ~]# getdatabaseparams
This command returns the db password. Use this password in this command:
[root@ mse ~]# /opt/mse/locserver/bin/tools/solid/solsql "tcp 2315" dba
Solid SQL Editor (teletype) v.06.00.1049
Copyright ©) Solid Information Technology Ltd 1993-2008
Connected to 'tcp 2315'.
Execute SQL statements terminated by a semicolon.
Exit by giving command: exit;
update AESSERVERINFO set USEHTTP=1;
Command completed successfully, 1 rows affected.
commit work;
Command completed successfully, 0 rows affected.
Press Control-C to exit the database shell. Perform
: Log onto MSE through ssh/console. Issue this command:
Hi Oscar,
The command doesn't work in my device. I also tried finding the directory but couldn't find it anywhere.
[root@spwifi-mse ~]# getdatabaseparams
hx+CPZ3y2UDwzhu
[root@spwifi-mse ~]# /opt/mse/locserver/bin/tools/solid/solsql "tcp 2315" dba hx+CPZ3y2UD9bzhu
-bash: /opt/mse/locserver/bin/tools/solid/solsql: No such file or directory
[root@spwifi-mse ~]# cd /opt/
[root@spwifi-mse opt]# cd mse
[root@spwifi-mse mse]# cd locserver
[root@spwifi-mse locserver]# cd bin/tools
[root@spwifi-mse tools]# cd solid
-bash: cd: solid: No such file or directory
[root@spwifi-mse tools]# ls
[root@spwifi-mse tools]# cd\
[root@spwifi-mse ~]# find / -name solsql
[root@spwifi-mse ~]# find / -name solid
[root@spwifi-mse ~]# find / -name mysql
[root@spwifi-mse ~]# find / -name sql
/opt/oracle/base/product/11.2.0/dbhome_1/.patch_storage/12534745_May_23_2011_02_15_51/files/sysman/admin/emdrep/sql
/opt/oracle/base/product/11.2.0/dbhome_1/.patch_storage/12534745_May_23_2011_02_15_51/original_patch/files/sysman/admin/emdrep/sql
/opt/oracle/base/product/11.2.0/dbhome_1/.patch_storage/12534748_May_23_2011_02_15_55/files/sysman/admin/emdrep/sql
/opt/oracle/base/product/11.2.0/dbhome_1/.patch_storage/12534748_May_23_2011_02_15_55/original_patch/files/sysman/admin/emdrep/sql
/opt/oracle/base/product/11.2.0/dbhome_1/.patch_storage/NApply/2013-03-12_12-16-24PM/backup/sysman/admin/emdrep/sql
/opt/oracle/base/product/11.2.0/dbhome_1/.patch_storage/12534747_May_23_2011_02_15_53/files/sysman/jlib/emDB.jar/oracle/sysman/emo/perf/bean/sql
/opt/oracle/base/product/11.2.0/dbhome_1/.patch_storage/12534747_May_23_2011_02_15_53/original_patch/files/sysman/jlib/emDB.jar/oracle/sysman/emo/perf/bean/sql
/opt/oracle/base/product/11.2.0/dbhome_1/oc4j/j2ee/oc4j_applications/applications/em/em/images/database/sql
/opt/oracle/base/product/11.2.0/dbhome_1/oc4j/j2ee/oc4j_applications/applications/em/em/database/instance/sql
/opt/oracle/base/product/11.2.0/dbhome_1/j2ee/OC4J_EM/applications/em/em/ecm/sql
/opt/oracle/base/product/11.2.0/dbhome_1/sysman/admin/emdrep/sql
/opt/oracle/base/product/11.2.0/dbhome_1/nls/csscan/sql
/opt/oracle/base/product/11.2.0/dbhome_1/owb/wf/sql
/opt/oracle/base/product/11.2.0/dbhome_1/owb/wf/admin/sql
/opt/oracle/base/product/11.2.0/dbhome_1/owb/rtp/sql
/opt/mse/install/dbpatches/12419278/12534747/files/sysman/jlib/emDB.jar/oracle/sysman/emo/perf/bean/sql
/opt/mse/install/dbpatches/12419278/12534748/files/sysman/admin/emdrep/sql
/opt/mse/install/dbpatches/12419278/12534745/files/sysman/admin/emdrep/sql
