cisco nexus 7000 swith module and cisco AP 2600
ngo duyen
we have network with  nexus 7009 core and a module  ML-148GS-11L
we are deploying cisco wireless in the netowrk. wlc 2504 and AP 2602I
wlc 2504 connect direct to ML-148GS-11L (trunk)
interface Ethernet5/35
  switchport
  switchport mode trunk
  no shutdown
If I connect AP 2600 through a swith 2960 which trunk with ML-148GS-11L, the AP register with wlc2504 and client can connect to wireless network
If I connect AP 2600 connect direct to  ML-148GS-11L (edge port, access), the AP register with wlc2504 but client cant see any SSID.
interface Ethernet5/37
  switchport
  switchport access vlan 99
  spanning-tree port type edge
  no shutdown
Does the module switch not compartible with AP 2600 ?
Regrads,
5 Replies 5
Leo Laohoo
You will probably not see the SSID because the M1 line card is NON-PoE.
All my ap use power injector. Anh the ap registed to the wlc
Ok, if the APs are UP and registered to the WLC:
1.  Is the SSID broadcasted in both 802.11a and 802.11b radios?
2.  Do you have "Broadcast SSID" enabled?
3.  Is the AP in the correct AP-Group?
hi Leo,
1. SSID broadcast all radios
2. "Broadcast SSID" enabled
3. All AP in default-group
and client cant get SSID from the AP which connect to M1 line.But at the same time, the client can connect to other APs which connected to nexus through a 2960x switch.
ngo duyen
AndThe AP work well if I connect with the M1 line through Fabric 2248TP
