Cisco Prime and ISE intergration
ittechk4u1
Level 4
Level 4
Hello Experts,
Earlier (Before SSL certificate installation) CPI and ISE was working together but now...I am struggling to get integrate CPI and ISE.
ISE version: 2.1.0.474
CPI: 3.5.0.0.55.0
Error(s): You must correct the following error(s) before proceeding:
Error: The connection to ISE with IP address "xx.xx.xx.xx" has timed out. Please check the network connectivity and the user account status on the ISE.
2 Accepted Solutions
Sandeep Choudhary
Did you installed the new certificates on both ? if yes then you need to delete the old certificate of ISE from Cisco prime CLI.
Dont forget to rate helpful posts
check under tofu-certs or trusted certs:
check the old certs: ncs certvalidation tofu-certs listcerts
Delete using the command: ncs certvalidation tofu-certs deletecert host IP_PORT
10 Replies 10
 Considering you actually have connectivity OK,  this probably a Bug.
-If I helped you somehow, please, rate it as useful.-
Even i guess so. I will check if i can raise a TAC case ..
pieterh
at first check if time-sync and time-zone match.
if this is both self signed certificate  then both need to "know" and trust each others certificate
if it is public certificate, then both bust know and trust the root and intermediate certificate in the chain.
Time is correct on both.
I installed wildcard CA signed cert on ISE and SSL cert signed by CA on cisoc prime but prime showing error "Mismatched address" as certificate error.
I suspect its the issue with TLSV1 handshake.
Sandeep Choudhary
Let me try it. Thank for suggestion.
can you please tell me how can i do it ? I tried but didn't find a way...
Excellent. It worked now after deletion of trusted old certs.
Thank a lot. you guys are awesome.
Glad it helped. Thanks for rating.
