212
Beginner
Cisco prime as SFTP server
I would like to copy file from local machine disk to Cisco prime disk. I have sftp client on my machine. How can I enable SFTP server on Cisco prime to transfer the file from client to server.
6 REPLIES 6
VIP Advisor
Re: Cisco prime as SFTP server
i do not believe PI has build in SFTP server, rather you can use SSH/SCP.
BB
*** Rate All Helpful Responses ***
Beginner
I found this on cisco portal where you can create an sftp user, but I could not get it working. I am getting an error that says permission denied. I tried to gain root access by issuing "sudo su" and then it doesn't find the directory when I try to issue "./sftpconfig.sh"
VIP Advisor
that was way back for 1.4X, now recent prime i do not belive you have that option.
BB
Participant
What version of Prime are you using?
VIP Advisor
3.2 is what we running, but 3.4 or 3.5 out soon going to be stable.
i do not believe or seen that option for myself.
BB
Highlighted
Beginner
We are using 3.4 version of Prime. I found that there is an option through TAC but do not have necessary commands to enable SFTP on cisco prime.
Content for Community-Ad
August's Community Spotlight Awards
