Community Live- Understanding How Multicast Works with Cisco
456
Cisco Prime Infrastructure - Access Point power level 0
Hello Team,
We are unable to manually change the power level of an AP on Cisco Prime Infrastructure 3.1.
We see on the prime that the power level is 0 (on the Cisco WLC, the power level is correct). See screenshot attached. Capture1.PNG
Whenever we try to change the power level of the AP in Prime, we receive the following error :
Error:Value for ''Previous Power Level'' is less than minimum allowed value ''1''
Error(s): You must correct the following error(s) before proceeding:
Does anyone has an idea? Is this related to a bug in Prime Infrastructure?
We know we can change the power level in the WLC also but our customer wants to do this via Prime.
The WLC is an AIR-CT5508-K9 with version 8.2.164.0 and the AP model is AIR-CAP2702I-E-K9.
Thanks in advance.
Yasim
4 REPLIES 4
Highlighted
Re: Cisco Prime Infrastructure - Access Point power level 0
How many AP's have this issue?
For testing purpose try the below workaround on any one AP:
Making an adjustment to the power level from the controller and re-synchronizing would move the current power level to the previous power level field correcting the issue. Then you can try changing the power level from PrimeInfra.
******* Please rate Useful post************
Hello Prasath,
Thanks a lot for your reply. It seems that it works after I change it on the WLC and then afterwards back on the Cisco Prime Infrastructure. I do not encounter this issue anymore on this AP.
I haven't seen this yet on our other AP's, but will do this if I encounter it again. Thanks again!
Kind regards,
Yasim
Glad that it worked ..
VIP Advocate
I think you're affected by this:
https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html#SNMPproblem
Also make sure you have installed the PI patches, in PI 3.2 a patch fixed such an issue.
Content for Community-Ad
August's Community Spotlight Awards
