Cisco vWLC Flexconnect / HA
awatson20
Level 4
Level 4
I was considering using the Cisco vWLC to replace some 5508's that are doing n+1 HA redundancy, however, it seems this controller only supports Flexconnect local switching.  So if I have distributed Cisco WLC's with AP's operating in local mode, failing to the vWLC would not work correct?
Hello
That´s correct. vWLC only support flexconnect local switching. You need to  change your topology in order to use vWLC.
-If I helped you somehow, please, rate it as useful.-
