01-10-2017 03:51 AM - edited 07-05-2021 06:20 AM
Dear All,
Need your feedback regarding cisco wireless lan controller 5520
Do we need to upload cisco boot image for cisco wlc 5520 controller in UCS Server..I am able to login to Cisco Intergrated Management controller but after that server goes to message in console saying "Cisco Bootloader Loading Stage 2..."
Need your input in this.
Thanks In Advance
02-27-2017 10:40 PM
Dear Scot,
In my deployment Scenario,5520 Management and Ap-Manager Interface are same, when i tried to used External Authentication Server like Radius Server to map with my Management Interface, Wireless users are not authenticated and in WLC log shows that radius server did not accept any request. But when i map with Service ip than users get authenticated. Since Service is not in production i cannot use that interface for mapping with radius server. So please suggest what i am doing mistakes here and also radius server is out of reach and access for which i cannot see the logs what is logged over radius server.
02-28-2017 08:18 AM
Radius by default uses the management interface. The service port address should not be routable and not have connectivity to the management port. On the wlan, there is a radius override in which you can specify the interface for radius:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/configuration/guides/consolidated/b_cg74_CONSOLIDATED/b_cg74_CONSOLIDATED_chapter_01100101.html
You shouldn't have to change this but make sure it's not pointing to your service port.
Also note, if it's working with the service port, that means the radius server aaa client for the controller has the service port address in which it should be the management address. Have your radius support team make sure the aaa client is defined using the management ip.
-Scott
03-14-2017 12:15 AM
12-04-2019 11:50 PM
07-21-2020 01:54 PM
I would like to know how you solved the "cisco bootloader loading stage 2" problem.
I am trying to enter by KVM and it throws me this message
07-24-2020 09:20 AM
07-24-2020 09:25 AM
12-03-2019 06:01 AM
Today I had done the CIMC upgrade and have got the same message " Cisco bootloader loading stage 2". This message is actually normal and doesn't represent the firmware is loading.
After I mapped the IOS file and rebooted ,this would show the Cisco UCS Host Upgrade utility. Afterwards it was showing me the above message . Just exit and login back to CIMC GUI and goto Admin > Firmware and proceed with Update option. This should work :) And I was connected through the console as well.
Thanks,,
Wireless_Guy
