08-03-2019 01:09 PM - edited 07-05-2021 10:48 AM
In all Cisco documentation, I've seen FlexConnect referred to as a per-AP feature (instead of per WLAN). Can I have an AP serve both WLANs that have the "FlexConnect Local Switching" on and off (under the Advanced tab)? I'm using a Cisco WLC 2504 controller.
08-03-2019 05:29 PM
Yes you can have one WLAN with local switching and one with central switching off the same AP. The AP will need to be in Felexconnect mode to do it though.
08-04-2019 12:28 AM
Thanks. And if the AP loses its connection to the WLC, will it only affect the WLAN that has "FlexConnect local switcing" enabled?
08-04-2019 01:32 AM
if the AP loses connection to the WLC, the centrally switched WLAN will stop working. The local switched on will go into standalone mode.
08-04-2019 01:26 PM
