03-23-2011 09:18 PM - edited 07-03-2021 07:59 PM
I have created a dhcp scope internally in WLC. The version of WLC is 4.2. please let me know Is it possible to clear this dhcp scope?
03-23-2011 09:25 PM
clear = deleting?
Then yes you cant...
Clear like clear the dhcp leased? :-s I guess it is not possible~! RELOAD the unit
03-23-2011 09:25 PM
if you are running 7.0 and above then its possible, if not then there is no option.. just now checked the same on my WLC.. the command is..
(WiSM-slot2-2) >config dhcp clear-lease ?
all Clear all Leases.
let me know if this answered your question!!
Surendra
03-23-2011 09:28 PM
GOOD to know!but he is running 4.2 ! :-s
03-23-2011 09:31 PM
Thats why shared the info!! so that he comes to know that we have that up on the latest!!
Surendra
03-23-2011 09:35 PM
I tried the command config dhcp clear-lease all.
But it is for the latest versions. Is there any option to clear the dhcp lease in wlc version 4.2?
03-23-2011 09:37 PM
yes its on 7.0 WLC and above!! not on 4.2
Surendra
03-23-2011 09:37 PM
Other than deleting it or reloading the WLC. Nop...
03-23-2011 09:37 PM
There is no option on 4.2.. As dmantill said reload will do it..
Surendra
03-23-2011 09:36 PM
Nice
03-23-2011 09:38 PM
ha ha ha Who is that!!
Surendra
03-23-2011 09:41 PM
Thankyou..
