CLI Login CAPWAP accesspoint associated in WLC
snarayanaraju
Level 4
Level 4
Hello All - How to do CLI Login of CAPWAP Wireless accesspoint that is already associated with a WLC. Though telnet is enabled, when tried login the accesspoint using the IP address of the accesspoint, it prompts for credential,
default credential "cisco/cisco" or the credential i use for login to WLC doesnt allow me to login the Accesspoint.
Appreciate if you can help me on this
regards/sairam
In WLC, select that AP & under credential tab, you can override it. Defined a username, password & enable password & hit apply. Then try to use that newly setup credential for that AP
If you like to change credential for all your APs, you can do that under global configuration in wireless tab
That should work
Rasika
*** Pls rate all useful responses ***
Did you try Cisco/Cisco ?
Rasika
Thanks Rasika - No it doesnt work. Cisco / Cisco fails
That should work
Rasika
Excellent. It worked.
Thanks again Rasika. You are great
