Popup Hotspot Using ISR 1000 with WiFi/LTE for Teleworkers and Micro Branchesr
Ask Me Anything – How to Enable Network Connectivity to Remote Workers
1987
Highlighted
Beginner
client association syslog message with 5500 wlc
Hi!
It is a Customer requirement to send 802.11 client association/disassociation logs to the Syslog server in a Unified Wireless system. (AIR-CT5508 + LAP1142)
With Autonomous APs it was easy; just send the following messages with the correct severity level:
*Mar  1 00:31:35.220: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   xxxx.xxed.5c2c Associated KEY_MGMT[WPAv2 PSK]
*Mar  1 00:31:55.861: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station xxxx.xxed.5c2c Reason: Sending station has left the BSS
Unfortunately I didn't find such logs even in Msg Log with the severity level set to debugging.
I was able to do client assoc/disassoc logging with SNMP trap + trap receiver software, BUT is there any way to do this with Syslog?
Andras
Everyone's tags (5)
1 REPLY 1
Highlighted
Re: client association syslog message with 5500 wlc
Anras:
Those info (like you mentioned) are sent to the SNMP trap receiver, not to Syslog. (you can choose what traps to send and you can select 802.11 association)
However, i don't know if changing the facility level to "Syslog" in WLC's logging config will change anything ( i don't think it will do anything but you can try it).
Amjad
Rating useful replies is more useful than saying "Thank you"
Content for Community-Ad
Cisco COVID-19 Survey
