Highlighted
Client roaming issue between APs
hello,
I have a wireless network built with Cisco WLC 5520 (in HA), AP 2800. WLC is running code 8.3.133.0.
Randomly, client roaming goes wrong, all I can found in the debug client is this :
xx:xx:xx:xx:xx:xx : MAC of client
yy:yy:yy:yy:yy:yy : BSSID
*Dot1x_NW_MsgTask_2: Nov 22 09:52:43.707: [PA] xx:xx:xx:xx:xx:xx Received EAPOL-Key from mobile xx:xx:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Nov 22 09:52:43.707: [PA] xx:xx:xx:xx:xx:xx Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile xx:xx:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Nov 22 09:52:43.707: [PA] xx:xx:xx:xx:xx:xx key Desc Version FT - 0
*Dot1x_NW_MsgTask_2: Nov 22 09:53:52.366: [PA] xx:xx:xx:xx:xx:xx Received EAPOL-key message in invalid state from mobile xx:xx:xx:xx:xx:xx
*apfOpenDtlSocket: Nov 22 09:55:08.983: [PA] xx:xx:xx:xx:xx:xx Recevied management frame REASSOCIATION REQUEST on BSSID yy:yy:yy:yy:yy:yy destination addr yy:yy:yy:yy:yy:y2
Every time it's the same debug, and loss of connection until the client reasscoates with the AP with reassociation request.
As you can see in this debug, about 1 minute and 16 seconde of loss of ping.
We use [WPA2][Auth(802.1X + CCKM)] with a remote radius server (ACS) a cross the WAN.
Any help is much appreciated.
regards,
Brahim,
1 ACCEPTED SOLUTION
Highlighted
Participant
Re: Client roaming issue between APs
8.3.133.0 is very old and with no software maintenance support - see https://www.cisco.com/c/en/us/products/collateral/wireless/8500-series-wireless-controllers/bulletin-c25-742339.html
If you *must* run 8.3 for some reason then you should be running 8.3.150.x Escalation code which TAC will still support - see https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html#anc11
If you don't have to stay on 8.3 (eg. for very old APs) then you should seriously consider moving to 8.5 or later.
3 REPLIES 3
Highlighted
hello,
I think somehow the client send eapol pkt with the key version 1 that's ignored by the controller (version 2).
is there a way to ignore the version check in the controller ?
*dot1xSocketTask: Nov 22 09:53:52.365: [PA] xx:xx:xx:xx:xx:xx validating eapol pkt: key version = 2
Thanks in advance,
Highlighted
Participant
Highlighted
Thank you for your reply, we moved to 8.5.151.0 recommanded by cisco.
We are in observation period.
Content for Community-Ad
Cisco COVID-19 Survey
