Highlighted
Client roaming issue between APs
hello,
I have a wireless network built with Cisco WLC 5520 (in HA), AP 2800. WLC is running code 8.3.133.0.
Randomly, client roaming goes wrong, all I can found in the debug client is this :
xx:xx:xx:xx:xx:xx : MAC of client
yy:yy:yy:yy:yy:yy : BSSID
*Dot1x_NW_MsgTask_2: Nov 22 09:52:43.707: [PA] xx:xx:xx:xx:xx:xx Received EAPOL-Key from mobile xx:xx:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Nov 22 09:52:43.707: [PA] xx:xx:xx:xx:xx:xx Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile xx:xx:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Nov 22 09:52:43.707: [PA] xx:xx:xx:xx:xx:xx key Desc Version FT - 0
*Dot1x_NW_MsgTask_2: Nov 22 09:53:52.366: [PA] xx:xx:xx:xx:xx:xx Received EAPOL-key message in invalid state from mobile xx:xx:xx:xx:xx:xx
*apfOpenDtlSocket: Nov 22 09:55:08.983: [PA] xx:xx:xx:xx:xx:xx Recevied management frame REASSOCIATION REQUEST on BSSID yy:yy:yy:yy:yy:yy destination addr yy:yy:yy:yy:yy:y2
Every time it's the same debug, and loss of connection until the client reasscoates with the AP with reassociation request.
As you can see in this debug, about 1 minute and 16 seconde of loss of ping.
We use [WPA2][Auth(802.1X + CCKM)] with a remote radius server (ACS) a cross the WAN.
Any help is much appreciated.
regards,
Brahim,
1 ACCEPTED SOLUTION
Highlighted
Enthusiast
Re: Client roaming issue between APs
8.3.133.0 is very old and with no software maintenance support - see https://www.cisco.com/c/en/us/products/collateral/wireless/8500-series-wireless-controllers/bulletin-c25-742339.html
If you *must* run 8.3 for some reason then you should be running 8.3.150.x Escalation code which TAC will still support - see https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html#anc11
If you don't have to stay on 8.3 (eg. for very old APs) then you should seriously consider moving to 8.5 or later.
5 REPLIES 5
Highlighted
hello,
I think somehow the client send eapol pkt with the key version 1 that's ignored by the controller (version 2).
is there a way to ignore the version check in the controller ?
*dot1xSocketTask: Nov 22 09:53:52.365: [PA] xx:xx:xx:xx:xx:xx validating eapol pkt: key version = 2
Thanks in advance,
Highlighted
Enthusiast
Highlighted
Thank you for your reply, we moved to 8.5.151.0 recommanded by cisco.
We are in observation period.
Highlighted
Beginner
Any update on this, please?
Highlighted
The upgrade solved the problem.
Content for Community-Ad
Cisco COVID-19 Survey
