Highlighted
Beginner
Clients with vlan privs can't roam
I changed my two Cisco Aironet 1401 APs to roam but now I have an issue with people who get put onto specific vlans.
The main WDS AP will has no issues putting people onto specific Vlans, but the 2nd AP is unable to do this now.
This is the error message I get, "Vlan id 27 from Radius server is not configured for station 28cf.dae3.4f16"
This is the config for AP1:
version 12.4
no service pad
service password-encryption
hostname cldap01
logging userinfo
logging buffered notifications
logging rate-limit console 9
logging console warnings
enable secret 5 <secret>.
aaa new-model
aaa group server radius rad_eap
server 10.12.10.4 auth-port 1812 acct-port 1813
aaa group server radius FreeRadius
aaa authentication login method_FreeRadius group FreeRadius
aaa authentication ppp default group radius
aaa authorization network default group rad_eap
aaa accounting update periodic 60
aaa accounting network default start-stop group radius
aaa accounting system default start-stop group radius
aaa session-id common
ip domain <domain>
dot11 syslog
dot11 vlan-name pwifi vlan 27
dot11 vlan-name wifi vlan 22
dot11 ssid <ssid>
   vlan 22
   authentication open eap rad_eap
   authentication network-eap eap
   authentication key-management wpa version 2
   guest-mode
crypto pki trustpoint TP-self-signed-1212998699
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1212998699
revocation-check none
rsakeypair TP-self-signed-1212998699
crypto pki certificate chain TP-self-signed-1212998699
certificate self-signed 01
<crypto>
  quit
!username Cisco privilege 15 password <removed>
username admin privilege 15 secret 5 <secret>
!username rancid password <removed>
ip ssh logging events
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 22 mode ciphers aes-ccm
encryption vlan 27 mode ciphers aes-ccm
broadcast-key vlan 22 change 300
broadcast-key vlan 27 change 300
ssid <ssid>
antenna gain 100
speed  basic-1.0 basic-2.0 basic-5.5 basic-11.0 basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
packet retries 100
channel 2412
station-role root access-point
rts retries 100
infrastructure-client
interface Dot11Radio0.2
encapsulation dot1Q 2 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.22
encapsulation dot1Q 22
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface Dot11Radio0.27
encapsulation dot1Q 27
no ip route-cache
bridge-group 27
bridge-group 27 subscriber-loop-control
bridge-group 27 block-unknown-source
no bridge-group 27 source-learning
no bridge-group 27 unicast-flooding
bridge-group 27 spanning-disabled
interface GigabitEthernet0
no ip address
no ip route-cache
duplex full
speed auto
no keepalive
interface GigabitEthernet0.2
no ip route-cache
bridge-group 1
interface GigabitEthernet0.22
no ip route-cache
bridge-group 2
interface GigabitEthernet0.27
no ip route-cache
bridge-group 27
interface BVI1
ip address 10.12.0.10 255.255.255.0
no ip route-cache
ip default-gateway 10.12.0.2
no ip http server
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
access-list 111 permit tcp any any neq telnet
snmp-server community ORVjkPtki8q RO
snmp-server location Solana Beach, California, USA
snmp-server contact OneRecovery NOC - <email>
snmp-server enable traps snmp authentication linkdown linkup coldstart
snmp-server host 10.12.10.3 ORVjkPtki8q
radius-server attribute 32 include-in-access-req format %i
radius-server attribute list 64
!radius-server host 10.12.10.4 auth-port 1812 acct-port 1813 key <removed>
!radius-server key <removed>
bridge 1 route ip
wlccp authentication-server infrastructure method_FreeRadius
wlccp wds priority 255 interface BVI1
line con 0
access-class 111 in
line vty 0 4
access-class 111 in
sntp server 10.12.10.4
end
This is the config for AP2:
version 12.4
no service pad
hostname cldap2
aaa new-model
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
clock timezone -0800 -8
ip domain name onerecovery.net
dot11 syslog
dot11 vlan-name test2 vlan 22
dot11 ssid <ssid>
   vlan 22
   mbssid guest-mode
crypto pki trustpoint TP-self-signed-1224361256
subject-name cn=IOS-Self-Signed-Certificate-1224361256
rsakeypair TP-self-signed-1224361256
crypto pki certificate chain TP-self-signed-1224361256
<crypto>
  quit
bridge irb
no ip address
no ip route-cache
broadcast-key vlan 22 change 60
ssid <ssid>
antenna gain 100
mbssid
channel 2462
no ip route-cache
bridge-group 1
no ip route-cache
bridge-group 2
no ip address
no ip route-cache
duplex full
speed auto
no keepalive
no ip route-cache
bridge-group 1
no ip route-cache
bridge-group 2
interface BVI1
ip address 10.12.0.11 255.255.255.0
no ip route-cache
no ip http server
snmp-server contact OneRecovery NOC - noc@onerecovery.com
radius-server attribute 32 include-in-access-req format %h
radius-server vsa send accounting
bridge 1 route ip
!wlccp ap username cldap2 password <removed>
wlccp ap wds ip address 10.12.0.10
line con 0
access-class 111 in
line vty 0 4
access-class 111 in
sntp broadcast client
end
Everyone's tags (2)
1 REPLY 1
Highlighted
Hall of Fame Master
Re: Clients with vlan privs can't roam
It's been a long time since I have done this, but AP 2 has no sub interface on vlan 27. What happens if you add vlan 27 on AP 2?
-Scott
Content for Community-Ad
