CMX 10 reinstall
Does anyone knows steps to reinstall CMX 10.x on MSE 3365 physical appliance? I have issues with my box and want to perform a fresh installation. I haven't seen a detailed guide on Cisco website on how to perform that.
Stanslaus.
You can also do it using the CIMC with the ISO. I had a TAC case with CMX like a year ago and they walked me through it. Don’t really remember the steps but the CIMC allows you to have the KVM access.
-Scott
5 Replies 5
Jeremy Hutterer
Create a bootable USB from a Cisco supplied .iso.  Then boot the box from that, I am not aware of any other way to do it.
-Scott
Hi Scott,
I did it via CIMC and went successfully.
https://www.cisco.com/c/en/us/td/docs/wireless/mse/8-0/MSE_CMX/8_0_MSE_CAS/8_0_MSE_CAS_chapter_010010.html
Stanslaus.
It’s so much easier that way:) Thanks for posting a link as that will help others whom may want to reinstall.
-Scott
Making a USB drive from the .iso didn't work well for me. Had to get a USB optical.
