06-19-2013 02:31 AM - edited 07-04-2021 12:15 AM
Question for the gurus!
Does RRM use MCS rates for AP neighbour RSSI?
If yes, then in a dense .11n only deployment would it be a good idea to remove low rates in the same way as we do for 802.11ag?
I'm looking to enable 16-QAM and better only to see if I can reduce channel utilisation on 2.4GHz. But if RRM doesn't use it I won't bother.
interested to hear if there any stories out there of negative side effects when disabling lower MCS rates?
Cheers!
Solved! Go to Solution.
09-13-2013 01:33 PM
RRM is sent at 1mbps, and max power. The WLC does some math around max and actual power for that AP, to decided if it needs to raise or lower power.
Now, for the 802.11n only deployment, yes you could go in and disable MCS0-7 and only keep the higher rates like we do with normal a/b/g deployment.
Tune, test, tune repeate till you have the results you are looking for
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
06-25-2013 09:41 PM
RRM refers to an algorithm which is used to minimise the interference, air quality, maximise SNR and efficient radio power.RRM reduces the need to perform exhaustive site surveys, increases system capacity, and provides automated self-healing functionality to compensate for RF dead zones and AP failures. It has nothing to do with MCS ( modulation coding scheme) index. MCS index is just a number mapping to different Modulation types from BPSK (0) to 64-QAM (31). Different modulation techniques have come up to increase the throughput , data rates. They have nothing to do with RRM algorithm.
06-25-2013 11:50 PM
In a dense environment, it's a good idea to disable the low-speed data rates of 802.11 b/g. In a dense deployment, I would always disable the data rates from 1 Mbps to 12 Mbps. I would make 18 Mbps as "Mandatory" and the rest are "Supported".
Because of the amount of the channels available for 802.11a/n, I tend to leave all the Data Rates enabled.
06-27-2013 06:07 AM
Unrelated but a fun nugget I learned and made me have a "oh!" moment.
When I looked at the rrm neighbor info I seen rssi values. I adjusted the power of the aps and the next read of rrm neighbor information didn't change .. Well I changed the tx power surely my rssi values should change .
I learned when the rrm packet is sent. It uses the lowest data rate 1 phy and the highest power of the radio. Regardless of static config ..
09-13-2013 01:18 PM
Say whaaat !
Dang I didn't know that.
So for example, if you have a perfect square, and 4 access points in each corner (simple fake setup). Bottom Left can see Top Right at -55 RSSI with power level set to 1 on both.
You then change power level to 8 on both , and you are telling me that we are still going to see RSSI neighbor information at -55 ?
How are we suppose to use the RSSI information to our advantage then if it never changes when we adjust settings manually? =(
Also, back to original posters question, which I don't think really got an answer.
If you disable a/n data rates all the way up to 54mbps for example, the MCS rates are still enabled from 0 - 23. Should we or should we not go in and manually uncheck the lower MCS rates (0, 1, 2...etc.) Otherwise those are sending at 7mbps and up etc., which in my mind leaves your cell size basically larger than you think it is.
Thoughts?
09-13-2013 01:33 PM
HTH,
Steve
09-13-2013 01:49 PM
You would only want to do that if all clients are 11n MIMO capable.
Otherwise 11n SISO clients would only be able to use 802.11ag rates with such a config.
So if you have 11n SISO clients then should enable some lower MCS rates (e.g. MCS 1 - MCS 7).
FYI, Cisco 11n Endpoints such as the DX650 have a single antenna so would not be able to utilize rates MCS 8 - MCS 15; can only utilize MCS 0 - MCS 7.
09-16-2013 07:26 AM
George,
Why not just disable RRM?
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a008072c759.shtml
I know it goes against the whole point of controller based APs, but in a stable environment, how often does RRM change power and/or channel?
09-14-2013 10:30 AM
I think he is referring to trimming the lowest MCS data rates, not the numerically lowest MCS numbers. So turning off 0,1,2,8,9,10,16,17,18 would turn off the BPSK/QPSK for all spatial streams.
09-16-2013 07:18 AM
You may not want to disable 0, some mobile devices are impacted by this
09-16-2013 08:04 AM
Thanks all - particularly George & Steve
Its good to know RRM is relative to a fixed modulation rather than whatever is enabled administratively.
I guess we make the assumption that BPSK range is equal for 802.11ag and 802.11n....
09-16-2013 08:16 AM
Did some more research on this....
Even with static settings, RRM will be functional and
it will still send neighbor messages to establish the RRM groups, and this cannot be shut off.
You can however increase the neighbor message interval under WIRELESS| 802.11B>RRM>General
Monitor Intervals (60 to 3600 secs)
Channel Scan Interval
Neighbor Packet Frequency
Eric
