06-22-2017 12:09 AM - edited 07-05-2021 07:14 AM
I want to know what is part 1 and part 2 shown below
I know it can change the boot image but what image is part 1 and 2 ?
Can I change them ?
AP#config boot path
<1-2> part1(1)/part2(2)
Solved! Go to Solution.
06-22-2017 04:00 AM
Partition.
Partition 1 and 2 are places where the AP stores the primary and secondary IOS.
06-22-2017 04:00 AM
Partition.
06-22-2017 06:35 PM
This a part of show version
AP Running Image : 8.3.102.0
Primary Boot Image : 8.3.102.0
Backup Boot Image : 8.2.121.0
You mean part 1 is primary and part 2 is backup ?
but I am running part 2 now , and I can change part 1 to part 2 by myself,is there any different between 1 and 2?
06-22-2017 07:08 PM
Partition 1 & 2 alternates which one is the "primary" or "secondary". It depends on the boot variable string of each individual APs. Some APs might boot Partition 1 and some might boot Partition 2.
Changing the which image the AP will boot will depend on what the firmware the WLC is running. You can force the AP to boot Partition 2 but if it is not the same firmware the WLC is running on, the WLC will force the AP to AP to boot the correct firmware.
06-22-2017 07:24 PM
I use Aironet 3802E
So part 1 is CAPWAP image ? part 2 is Mobility Express image ?
Is that right?
06-22-2017 09:12 PM
It could be any. It is not necessary to Partition 1 will always be CAPWAP and Partition 2 will always be MobEx. It can go either way.
06-22-2017 09:52 PM
Thanks a lot !
10-09-2019 08:56 AM
How can I have both partitions with the same version number?
10-25-2019 04:07 AM
Why I configure to part 1 but it's not change, it always boot the path 2 image?
Thank you very much.
11-17-2022 02:08 AM
It is always best practice to have different images on the parts so if any defect arise on the active you can always roll back to a previous one without spending additional time to download the new image.
