Community Live- Understanding How Multicast Works with Cisco
157
Beginner
Confuration of a 1532i Access point
I Have a 1532i and have configured if for autonomous mode got everything working with the survey ssid I need.
The signal strength that I have from it is very poor all setting for transmit power are set to max but still very poor I have a 2600 which is far more powerful.
Does anyone know of any other setting which would increase the signal strength.
2 REPLIES 2
Highlighted
Rising star
what is the RSSI value in
what is the RSSI value in client statistics? Can you check for the correct powering source/ injectors?
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1530-series/guide-c07-729725.html
Beginner
I'm using this Access Point
I'm using this Access Point as a stand alone Survey AP. I'm using Cisco power supply DPSN-35FB A.
The AP shows no issue with power.
Not had to change any other values in the 2600 I'm using at the moment for Surveys.
Set up much the same but signal for the 1532 is very low.
Content for Community-Ad
August's Community Spotlight Awards
