09-19-2018 02:41 AM - edited 07-05-2021 09:12 AM
Is it possible to convert access point 1815w from Lightweight to Autonomous without the console adapter (Part Number: AIR-CONSADPT=)?
Solved! Go to Solution.
09-20-2018 09:07 AM
There is no such command.
(Cisco Controller) >license ?
clear Clear a License
comment Manage the comment string of a License
install Install a License
modify Modify the Priority of a License
revoke Revoke or Rehost a License
save Save a License
(Cisco Controller) >show license all
License Store: Primary License Storage
StoreIndex: 0 Feature: base Version: 1.0
License Type: Permanent
License State: Active, Not in Use
License Count: Non-Counted
License Priority: Medium
StoreIndex: 0 Feature: base-ap-count Version: 1.0
License State: Active, In Use
License Count: 5 / 5 (Active/In-use)
License Store: Evaluation License Storage
StoreIndex: 1 Feature: base-ap-count Version: 1.0
License Type: Evaluation
License State: Inactive
Evaluation total period: 12 weeks 6 days
Evaluation period left: 12 weeks 6 days
License Count: 75 / 0 (Active/In-use)
License Priority: None
09-20-2018 12:51 PM
09-21-2018 12:13 AM
Yes, something is wrong with the licenses.
I tried to activate a trial license for 75 AP, but also the situation:
License Count: 5 / 0 (Active/In-use)
Evaluation period left: 12 weeks 5 days
License Count: 75 / 75 (Active/In-use)
License Priority: High
09-21-2018 03:47 AM
09-21-2018 07:15 AM
Did you reboot the controller after enabling the evaluation licenses ?
Can you run these to commands
>show license evaluation
>show license summary
09-24-2018 03:18 AM
Yes, I rebooted the WLC.
Now 75 licenses are deactivated.
(Cisco Controller) >show license evaluation
License Priority: Low
(Cisco Controller) >show license summary
09-25-2018 08:56 AM
09-26-2018 12:41 PM
Solved!
The access point was registered in WLC after adding the DHCP settings on the L3 switch:
- option 4 (ip address Time Server)
- option 42 (ip address NTP Servers)
- domain-name
- update arp
What exactly influenced is not clear. After removal of these settings, the access point is still registered.
Next, I changed the firmware on the access point to the ME.
Best regards,
Maxim.
