Converted AP to autonomous can telnet but no longer login to web page with credentials
Andrew White
Level 2
Level 2
I have converted an AP to autonomous for a small office, it rebooted and I could get onto the webpage fine until I changed the username and password, now it doesn't accept anything.
What is strange I can access it via telnet and I've added a priv 15 account and still can't access the web page, it does prompt though.  It seems only http is available and not https.
Any ideas?
20 Replies 20
Did you try with different browser or clearing cache ?
Yes, you have to use HTTP & . not HTTPS
Rasika
I've reset and just trying to setup 1 SSID on the 5Ghz.
I is just on my home network which is a flat network with a basic ISP router.  I assume it's just VLAN 1.  I can see my SSID but it never accepts my password.
What have I done wrong?
Cisco-AP1#sh run
Building configuration...
Current configuration : 2236 bytes
! Last configuration change at 03:20:29 UTC Mon Mar 1 1993
version 15.3
no service pad
service password-encryption
hostname Cisco-AP1
logging rate-limit console 9
enable secret 5 $1$ixbW$6V0IJ8.n3gJIdf5xir/CI/
no aaa new-model
no ip source-route
no ip cef
dot11 pause-time 100
dot11 syslog
dot11 ssid Area51-5Ghz
   vlan 1
   authentication open
   authentication key-management wpa version 2
   guest-mode
   mobility network-id 1
   wpa-psk ascii 7 122A150200185D547A
no ipv6 cef
username Cisco password 7 1531021F0725
username ***** privilege 15 secret 5 $1$dMlY$4tZHLRaPyVztaJtXn/.
bridge irb
interface Dot11Radio0
 no ip address
 encryption mode ciphers aes-ccm
 antenna gain 0
 station-role root
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Dot11Radio1
 no ip address
 encryption vlan 1 mode ciphers aes-ccm
 ssid Area51-5Ghz
 antenna gain 0
 peakdetect
 no dfs band block
 stbc
 channel dfs
 station-role root
interface Dot11Radio1.11
 encapsulation dot1Q 1 native
 bridge-group 1
interface Dot11Radio1.111
interface GigabitEthernet0
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0.1
 bridge-group 1
interface GigabitEthernet0.11
interface GigabitEthernet0.111
interface BVI1
 mac-address 80e0.1dbc.df30
 ip address dhcp client-id GigabitEthernet0
 ipv6 address dhcp
 ipv6 address autoconfig
 ipv6 enable
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community m0n1t0r RO
bridge 1 route ip
line con 0
line vty 0 4
 login local
 transport input all
end
Hi Andrew,
I would erase startup config & reload without saving. In that way AP comes with zero config.
Then apply below simple configuration (modify parameters within <> sections) & plug it to your ISP modem. That should work.
To access AP Web GUI, you need to know which IP AP got via your ISP modem and then use http://<ap_ipaddr> with that admin user credentials.
To connect to SSID, you have to use the <SSID_Password> configured.
conf t
hostname Cisco-AP1
username <ADMIN_USER> privilege 15 secret <ADMIN_PASSWORD>
authentication open
guest-mode
wpa-psk ascii <SSID_PASSWORD>
channel width 40-above
ssid Area51-5Ghz
no shutdown
interface BVI1
ip address dhcp
end
write memory
By the way, what is the AP model, I have set it to 40MHz on 5GHz radio, assuming it is 802.11n model. If it is not 11n, that command will reject (you can ignore it).If it is 11ac, then you can configure it to use 80MHz if needed.
Rasika
*** Pls rate all useful responses ***
Thanks this all worked!  It's as AC AP so I set the 5Ghz to 80 and my 2.4Ghz on the default of 20.
1.) Now how would I set the the 'Area51-5Ghz' SSID to VLAN 140 and the other to 141?  My switch port is set to a trunk at the moment and I have DHCP running on both VLANs.
2.) Also I need to turn on SSH and https and turn off telnet and http.
Hi Andrew,
That's good to hear.
1. For multiple vlan, where to you configure dhcp for those multiple vlan ? typically service provider modem is not capable of multi-vlan & 802.1Q trunk configuration.
2. You can simply configure SSH like below (you can modify domain-name as necessary)
AAP1(config)#ip domain-name mrn.local
AAP1(config)#crypto key generate rsa modulus 2048
AAP1(config)#ip ssh version 2
AAP1(config)#line vty 0 4
AAP1(config-line)#transport input ssh
AAP1#wr mem
You can simply disable http & enable https like below
AAP1(config)#no ip http server
AAP1(config)#ip http secure-server
% Generating 1024 bit RSA keys, keys will be non-exportable...
[OK] (elapsed time was 1 seconds)
Rasika
Thanks, I’ve installed a pfSense firewall that can do VLANs, DHCP per VLAN and all the Layer 3 stuff.
Ok, if that is the case you have to configure switchport end where you plug your AP as trunk port. Your AP management vlan has to be untagged (native vlan) on that trunk.
Here is a sample config with 3 SSID. In this config vlan 999 is native vlan with 192.168.99.0/24 is subnet assigned to it. Vlan numbers 1,2,& 3 used with respective SSIDs. Note that bridge-group 1 has to associate with native vlan mapped interfaces (x.999 in my case)
hostname AP-01
dot11 ssid SSID-1
vlan 1
authentication open
mbssid guest-mode
wpa-psk ascii <SSID_1_PASSWORD>
dot11 ssid SSID-2
vlan 2
authentication open
mbssid guest-mode
wpa-psk ascii <SSID_2_PASSWORD>
dot11 ssid SSID-3
vlan 3
authentication open
mbssid guest-mode
wpa-psk ascii <SSID_3_PASSWORD>
encryption vlan 2 mode ciphers aes-ccm
encryption vlan 3 mode ciphers aes-ccm
mbssid
ssid SSID-1
ssid SSID-2
ssid SSID-3
no shut
mbssid
ssid SSID-1
ssid SSID-2
ssid SSID-3
no shut
interface Dot11Radio0.1
bridge-group 10
interface Dot11Radio0.2
encapsulation dot1Q 2
bridge-group 20
interface Dot11Radio0.3
encapsulation dot1Q 3
bridge-group 30
interface Dot11Radio0.999
encapsulation dot1Q 999 native
bridge-group 1
bridge-group 10
interface Dot11Radio1.2
bridge-group 20
interface Dot11Radio1.3
bridge-group 30
interface Dot11Radio1.999
bridge-group 1
bridge-group 10
interface GigabitEthernet0.2
bridge-group 20
interface GigabitEthernet0.3
bridge-group 30
interface GigabitEthernet0.999
bridge-group 1
interface BVI1
ip address 192.168.99.101 255.255.255.0
ip default-gateway 192.168.99.1
end
write memory
Rasika
*** Pls rate all helpful responses ***
Wow this great, I will certainly try this.
Also I've attached this 3702i AP to my PoE Ubiquiti switch and it's powering it fine and we are connecting, but I get a warning it doesn't have enough power.  I think it needs 15.4w and uses 802.3af which my switch supports, but the switch shows it's only using 7w.  I'm not sure if I can lower the power for the AP or the mimo?
One more little detail. The secret 5 and 7 password hashes can easily reverted back into clear text. I suggest you remove them from your first post, unless you want other users to know your passwords.
The 3702i actually needs PoE+ with around 16.8 Watts for full functionality. Your switch sadly can't provide enough, so it will run in somewhat reduced performance mode.
Datasheet: https://www.cisco.com/c/en/us/products/collateral/wireless/3700-series-access-point/data_sheet_c78-729421.html
Yes the passwords have been changed. I guess I could use an injector. What does reduced power actually do?
I know that you have changed the passwords, it's just that they can be decrypted by anybody instantaneously :) There are websites where you can copy paste the shown string and you'll get the cleartext password back.
Reduced power (assuming it has PoE, but not PoE+) will reduce the wireless performance by around 15-30%. The covered range will probably also be a bit smaller. From the datasheet:
Description
AP Functionality
PoE:
3700 - No external module installed
3x3:3 on 2.4/5 GHz
PoE+:
4x4:3 on 2.4/5 GHz
Hi Rasika,
Sorry to trouble you.  Are you able to help me with a simple config for my Cisco 3702i AP.  You example is great, but I'm not sure how to do the following:
My home LAN is on 192.168.0.x/24 and I have 2 Cisco APs.  Only one is in use at them moment in autonomous mode on 192.168.0.x and plugged into my Ubiquiti UniFi switch and has 2 SSIDS 1 for 2.4Ghz and the other on 5Ghz and works well.
I now want to get my second AP on it's own VLAN.  I have a pfSense firewall as a VM in my ESXi host and I've created VLAN 141 (192.168.141.x) and from my PC I can ping the virtual gateway on 192.168.141.1.  I now want to configure the new AP with 2 SSIDs for 2.4/5Ghz on VLAN 141.  Are you able to provide a config that might help?  I'm not sure if the Ubiquiti switch understands native VLANs.  Would it looks something like this?
hostname AP-01
dot11 ssid SSID-1
vlan 141
authentication open
mbssid guest-mode
dot11 ssid SSID-2
vlan 141
authentication open
mbssid guest-mode
encryption vlan 141 mode ciphers aes-ccm
mbssid
ssid SSID-1
no shut
mbssid
ssid SSID-2
no shut
interface Dot11Radio0.141
encapsulation dot1Q 141
bridge-group 141
bridge-group 1
interface Dot11Radio1.141
bridge-group 141
bridge-group 1
interface GigabitEthernet0.141
bridge-group 141
bridge-group 1
interface BVI1
end
write memory
To do this you need to plug AP on vlan 141 switch port.
How are you extend that vlan 141 out of firewall/VM ? Is it connect to your switch ?
For testing I would suggest, you wired connect a PC (configured with vlan 141 IP)to your switch  & see if you can ping your firewall gateway IP from that PC.
If that works, then it is straight forward. First check it and let me know
Rasika
Wow thanks.
My Home Wifi will be on VLAN 141 so will my BVI interface be something like this:
ip address 192.168.141.10 255.255.255.0 (IP for AP management)
ip default-gateway 192.168.141.1 (virtual interface on pfSense.  This is setup and pingable)
Plus I would need to enable DHCP on pfSense for VLAN 141.
