152
Highlighted
Beginner
debug capwap console cli not working
I'm trying to manually add SNMP config to a WAP.  cisco tac recommended debug capwap console cli then conf t and adding the SNMP config but I can't get that far.  where do I go from here?
WAP#debug capwap console cli
% Invalid input detected at '^' marker.
WAP#debug capwap
client CAPWAP Client debugs
WAP#debug capwap client
avc CAPWAP client AVC
detail CAPWAP detail
efficient-upgrade Smart image download debugging
error CAPWAP error
events CAPWAP events
flexconnect CAPWAP flexconnect mode event
info CAPWAP info
keepalive CAPWAP keepalive
payload CAPWAP payload
pmtu CAPWAP Path MTU debugging
qos CAPWAP qos
reassembly CAPWAP reassembly
security CAPWAP security
WAP#show version
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
Cisco AP Software, (ap3g3), [wnbu-bld-lnx8:/san/BUILD/workspace/83MR4_Repost_Cheetah_CCO/label/barbados]
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Mon Jun 4 23:25:52 PDT 2018
ROM: Bootstrap program is U-Boot boot loader
BOOTLDR: U-Boot boot loader Version 2013.01-gad8bd06 (Sep 28 2017 - 17:03:04)
ALDLEG-6-WAP07-6302-D552 uptime is 0 days, 6 hours, 45 minutes
Last reload time : Thu Apr 4 21:09:33 UTC 2019
Last reload reason : unknown
cisco AIR-AP3802I-B-K9 ARMv7 Processor rev 1 (v7l) with 1030640/710480K bytes of memory.
Processor board ID FCW2243NFQP
AP Running Image : 8.3.143.0
Primary Boot Image : 8.3.143.0
Backup Boot Image : 8.2.166.0
1 Multigigabit Ethernet interfaces
1 Gigabit Ethernet interfaces
2 802.11 Radios
Radio Driver version : 9.0.5.5-W8964
Radio FW version : 9.1.8.1
NSS FW version :
Base ethernet MAC Address : F4:DB:E6:9D:D5:52
Part Number : 73-018550-02
PCA Assembly Number : 000-00000-00
PCA Revision Number :
PCB Serial Number : FOC22415XWY
Top Assembly Part Number : 068-100730-02
Top Assembly Serial Number : FCW2243NFQP
Top Revision Number : E0
Product/Model Number : AIR-AP3802I-B-K9
3 REPLIES 3
VIP Engager
Re: debug capwap console cli not working
It's running in CAPWAP mode, so I don't think it's possible to add SNMP configuration on the AP direct. You will have to do that on the WLC, only for the WLC.
What do you actually try to achieve?
Debug capwap is for debugging association event between the AP and the WLC. You actually get most of those events by simply attaching a console cable to the AP and reboot it. The other messages are on the WLC, where you have to enable it by 'debug capwap events' (there are more variations for debug capwap).
Beginner
That's a COS (ClickOS) AP (Wave 2 and later). I recall seeing that that command is only valid for the older IOS based APs.
Suggest you go back to TAC.
Like Pat I would also question why you're even trying to configure SNMP on a CAPWAP AP - you should be polling the WLC not the AP - that's the whole purpose of the CAPWAP design. If you want a locally managed AP you may want to consider ME (Mobility Express) where the AP effectively becomes a mini WLC + AP (autonomous IOS is not available for these APs).
Hall of Fame Master
Like others mentioned, that command is only valid of the Wave1 and older AP's. SNMP is done from the controller and not individual access points.
-Scott
ask the Expert- Cisco's Branch Routing Portfolio
