Deploy a new 5508 as a secondary WLC into network
prafranc1
Hi Friends,
I'm really poor in WLC deployment.
I need to deploy a new 5508 WLC into network as a secondary controller. The primary WLC (5508) has been configured as a single WLC as of now and working good.... Now I need to deploy the new 5508 as the secondary controller.
I could connect to the console and do the basic configs. (Service interface and Management int IP Addresses etc,)
Now I need to perform two tasks:
1) I should synchronize the configuration from the primary 5508 to the secondary 5508 which i have just added. Please guide me how to do it?
2) I need to configure the HA (failover) using the RP or by giving static Pri/Sec/Ter per AP.
Please help me ASAP as I am not much used to WLC deployments.
Francis
Sandeep Choudhary
HI,
  1. Is it a HA-SKU license model(secondary )?
  2. Or do you have atleast 50 AP license on secondary WLC ?
If you have one of the mentioned above then go through this guide:
http://networkguy.de/?p=558
http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/7-5/High_Availability_DG.pdf
Dont forget to rate helpful posts
5 Replies 5
Sandeep Choudhary
HI,
Thanks for the reply...
Please find the show license summary results of Primary and Secondary 5508 WLCs pasted below:
Kindly guide me if the license is good to get the redundancy....
Primary 5508 WLC> sh license summary
License Store: Primary Licene Storage
Store Index:  0  Feature: base                    Version 1.0
    License Type: Permanent
    Lincense State: Active, Not in Use
    License Count : Non-Counted
    License Priority: Medium
License Store: Primary License Storage
StoreIndex:  1  Feature: base-ap-count                Version 1.0
    License State: Active, In Use
    License Count: 25/25 (Active/In-use)
License Store: Evaluation License Storage
StoreIndex: 0   Feature: base-ap-count                Version 1.0
    License Type: Evaluation
    License State: Inactive
        Evaluation total period:    8 weeks 4 days
        Evaluation period left :   8 weeks  3 days
        License Count: 500 / 0 (Active/In-use)
    License Priority: Low
Secondary 5508 WLC> sh license summary
    License State: Active, Not in Use, EULA not accepted
    License Priority: None
As per screenshot, I can only say that :
primary WLC has 25 AP license.
secondary don't have any base AP license but I think it has HA SKU license.( you can check what's written on invoice for decoy day WLC, it must be as AIR-5508-HA)
dont forget to rate helpful posts
Thanks again Sandeep....
It would be great if I could get it confirmed that the licensing part is okay....
Thank you...
You invoice can show the part number you baught. ( it will tell the exact license type)
