Community Helping Community
165
Highlighted
dhcp address problem wlc 5508
HELLO I HAVE THE PROBLEM WITH DISCONECTION CLIENT DHCP
can someone help me with this issue.
Everyone's tags (1)
3 REPLIES 3
Collaborator
Re: dhcp address problem wlc 5508
Could you share your SSID configuration? This DHCP server is under a L3 device? Are you using DHCP relay?
If possible share the configurations.
Jaderson Pessoa
*** Rate All Helpful Responses ***
Hello DHCP server is external device.ande send show tech of the device.
Collaborator
@Rafael Mauricio Navarrete Echegoyen
I have found something in your configuration, could you check it?
VLAN....................................................... 8
Primary DHCP Server.............................. 10.160.42.2
DHCP Proxy Mode.................................. Global
VLAN....................................................... 854
Primary DHCP Server.............................. 10.252.58.196
VLAN.......................................................... 401
Primary DHCP Server................................. 10.92.200.51
Secondary DHCP Server............................ 10.92.200.52
Maybe configurations below are overlapping your dhcp above. Could you remove them?
wlan dhcp_server 2 0.0.0.0 required
wlan dhcp_server 3 0.0.0.0 required
wlan dhcp_server 5 10.160.50.4 required
Jaderson Pessoa
Content for Community-Ad
August's Community Spotlight Awards
