07-20-2016 07:12 AM - edited 07-05-2021 05:27 AM
Hi all,
In our business we have 7 AP that are AIR-AP1852E-x-K9C with cisco mobility express image on each one.
We need to add an extra access point; can we buy an AIR-AP1852E-x-K9 or we need an other AIR-AP1852E-x-K9C? what are the differences between C and non C version?
thanks!
Paolo
07-20-2016 06:11 PM
Model numbers ending in C are, by default, factory-shipped with a Cisco Mobility Express software image., you need to purchase K9C else if you purchase with normal image CAPWAP, you have to convert it to Mobility express.
07-15-2019 07:44 AM
do I understand it right that I can run one AP "AIR-AP1852E-E-K9C" as Master (Controller AP) and the others can be the normal "AIR-AP1852E-E-K9"?
Thanks!
07-15-2019 11:41 AM
That is correct. K9C will be Mobility Express Controller (Master) and the rest can be K9 APs.
CJ
07-16-2019 12:46 AM
Is there any evidence in official documents that I do not see or understand?
In any case, many thanks for the answer.
That will help me for now!
07-16-2019 07:10 AM
Refer Ordering section in the following document
Also, the Mobility Express Deployment Guide: Table 1 & 2
07-18-2019 07:52 AM
Do you know if K9C-APs (APs with mobility express software) can also be managed by a controller, e.g. AIR-CT3504-K9, or does the other image have to be installed?
07-19-2019 07:46 AM
