Documentation for "EAP Parameters" option in Cisco 2504 WLC WLAN
Sam Brynes
Does any one have any documentation for the "EAP Parameters" option in a Cisco 2504 WLC WLAN under WLANs > Security > AAA Servers?
Probably pretty self-explanatory, but what if we don't select the "Enable" checkbox?
Are default values used if we do not have that box checked? And what are the default values that are used if the "Enable" checkbox is not selected?
Yes, default values will be used even if you do not enable that checkbox on GUI & modify.
You can use "show advanced eap" CLI command on your WLC to see the default settings for EAP parameters
Rasika
*** Pls rate all useful responses ***
