02-03-2017 01:25 PM - edited 07-05-2021 06:30 AM
The power output on the 3750X switch is 30W, and the requirement for a Cisco 3802 Access Point is 30W. Will the Cisco 3750X be able to provide enough power to the access point or will I need to move to a 3850 switch, which provides 60W of power, to be able to power a Cisco 3802 AP?
Solved! Go to Solution.
02-03-2017 01:59 PM
Assuming you have standard length cable runs and enough spare PoE budget on the 3750X - it will be fine.
02-03-2017 01:59 PM
02-03-2017 03:04 PM
thanks.
