Highlighted
Beginner
Does Aironet 1852e support interference detection and channel selection
Hello , I have a question about Cisco Aironet 1852e AP ,
does this AP supports interference detection ?
if it support ,when the AP on a channel with interferences ,
does it change the channel automatically ?
thank you for your answer.
2 REPLIES 2
Highlighted
Hall of Fame Community Legend
CleanAir, by default, is disabled.  Enable CleanAir and it will detect inteference.
EDRRM, Event Driven Radio Resource Management, is disabled by default.  Enable this allows the AP to change channel when interference is detected to be strong.
Beginner
Thank you for your help , I
Thank you for your help , I saw the setting step on controller on the Cisco website ( Figure1 and Figure2 ) .
but my AP's GUI does not like that , I found a similar GUI on the Internet ( Figure3 ) .
Does my AP can do the things of interference detection and change channel when the interference is detected to be strong automatically ?
p.s. My AP's firmware type is Mobility Express , version is 8.3.112 ,  and there is a virtual controller in the AP .
Content for Community-Ad
