03-05-2012 07:27 PM - edited 07-03-2021 09:43 PM
i have a controller that has mutliple dhcp scopes and should in theory give out close to a thousand plus addresses. But i have seen wireless users not getting addresses once the controller has leased about 490 ip adds. anyone see anything like this or know of any known bugs? my controller is on 7.XX version.
03-05-2012 10:13 PM
If you are on 7.0.98.0, then you could definitely be hitting: CSCth68708 and is resolved in 7.0.98.218. If you are on 7.0.98.0 I would highly suggest moving on up to the latest release 7.0.230.0, if your infrastructure allows.
If the version is not 7.0.98.0, how have you verified that the WLC is not "handing out" addresses other than the clients not getting one? Do you have a capture/debug?
03-06-2012 03:08 AM
I second David about the bug issue.
This was very common for those on 7.0.98.0 or 6.0.199.0.
03-06-2012 06:55 AM
My version is 7.0.220.0. I do not have a capture (will be doing so), but when I look at the controller stats for dhcp leases, I have never seen it go above 500 leases, although I have several scopes (multiple ssids), and I know we should be giving out more leases. My lease time-outs for diff. scopes are set for 30 mins, 3 hours , 2 hours etc.
