164
Beginner
EAP-PEAP configuration on WLC
We are trying to deploy a wlan network for the clients to support for EAP-PEAP.
There is no RADIUS/Active directory will be used here.
In this case, can the certificate be directly installed on the cisco WLC and Cisco WLC will act as authentication server(enablement of PSK ).
If yes, then which steps to be followed to upload the certificate?
Everyone's tags (1)
3 REPLIES 3
VIP Mentor
Re: EAP-PEAP configuration on WLC
Beginner
Thank you.
The provided links are very useful.
I am looking for the certificate to be installed only on the WLC. The client devices will have to use user credentials to connect to the said WLAN. Would this work in this case?
VIP Mentor
it will work but i nevered really tested it...
More info here:
https://mrncciew.com/2013/04/22/configuring-eap-tls-on-wlc/
Best case would be to have ISE(Radius server) , AD
Dont forget to rate helpful posts
Content for Community-Ad
August's Community Spotlight Awards
