Community Helping Community
125
Highlighted
Beginner
EAP-TLS Flexconnect roaming
I have a problem with SSID that use EAP-TLS (Radius server NPS) when my computer change AP.
I see that my computer lost connection and make a dhcp request and a new authentification.
In a cisco best pratice for flexconnect I saw that the option DHCP Addr Assignment required must be disable.
I try it but it's the same problem.
My configuration is :
WLC 5508 version 7.4.121.0
AP 1602
Computer with intel 7265 in version 18.40.0.0 CCKM 4.0
My SSID is in flexconnect WPA+WPA2 (policy + AES)
Fast transition is enable
Over the DS enable
Reassociation Timeout 20s
PMF Disabled
Authentication key 802.1x + CCKM
Flexconnect local switching enable
Lear client ip address enable
DHCP Addr assignment not required
And my ap are in the same flexconnect group
CLient Roaming RF parameters mode Custom
Min RSSI -75dBm
Hysteresis 3 db
scan Threshold -70 dbm
Transition time 5s
Thanks for your help.
Content for Community-Ad
August's Community Spotlight Awards
