Easy log file question for AP 1200
matthogue
I am wanting to troubleshoot the last week's log on a AP, but it only shows 12 hours.
What is the config I need to run to save the logs from the last restart to a file on a server?
Thanks for any info.
5 Replies 5
bcolvin
Level 3
Level 3
Matt
It is not practical to store that large a log file on the AP due to memory limits. The solution is to configure a syslog server on a PC and then configure the AP to log events on hte server. You can use tftp32.exe for the syslog server function.
Bill
micahcox
setup the syslog server with tftp32.exe
enter "logging "
The AP will log to "local7" on the syslog server.
micahcox
enter "logging "
micahcox
enter "logging "
Thanks for the replies from both of you.
We do have logging facility local0 setup, which I am assuming is just logging on the AP itself.
I will get with the network team to set up a pc as the syslog server and see what happens.
thanks and I'll let you know how it goes.
Matt
