Community Helping Community
272
Highlighted
Beginner
enable 300mbps at autonomous CAP3702e radio0
Hi guys.
I'd like to enable 300 for n mode clients (they are not not ac compatible) at autonomous access point CAP3702e.
I applied followin configuration:
dot11 vlan-name a81m vlan 11
dot11 ssid a81m
vlan 11
authentication open eap EAP_METHODS
authentication network-eap EAP_METHODS
authentication key-management wpa version 2
mbssid guest-mode
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 11 mode ciphers aes-ccm
encryption mode ciphers aes-ccm
ssid a81m
antenna gain 0
stbc
mbssid
speed basic-6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. m16. m17. m18. m19. m20. m21. m22. m23.
channel least-congested 2437 2462
station-role root
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.11
encapsulation dot1Q 11
no ip route-cache
no cdp enable
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 spanning-disabled
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
ssid a81m
antenna gain 0
peakdetect
dfs band 3 block
stbc
mbssid
speed basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. m16. m17. m18. m19. m20. m21. m22. m23. a1ss9 a2ss9 a3ss9
channel width 40-below
channel dfs
station-role root
no cdp enable
bridge-group 1
interface Dot11Radio1.11
no ip route-cache
no cdp enable
bridge-group 2
interface GigabitEthernet0
description -= .1q trunk to gate's gi6 - private VLAN 11 =-
no ip address
no ip route-cache
duplex auto
speed auto
interface GigabitEthernet0.11
description -= private wireless subnet 192.168.172.16/28 =-
no ip route-cache
bridge-group 2
no bridge-group 2 spanning-disabled
interface BVI1
description -= management subnet 192.168.172.0/28 =-
mac-address e865.1998.2fc4
ip address 192.168.172.11 255.255.255.240
no ip route-cache
interface BVI2
mac-address 0005.4938.23c6
no ip address
no ip route-cache
as results. whenever GN clients joined AP, successfully authenticated but getting just 150 mpbs.
I tried to setup "aXssXX" parameters for interface Dot11Radio0 but there is no options to do that.
Could you suggest?
p.s. interface bvi1 is AP management link.
Thank you.
Everyone's tags (1)
2 REPLIES 2
Hall of Fame Community Legend
Re: enable 300mbps at autonomous CAP3702e radio0
The AP might support >300 Mbps but this will depend entirely if the wireless client(s) can support this speed or not.
Hall of Fame Master
Leo is correct... depends also on you devices. However, 5GHz is where you will see higher throughput.
-Scott
Content for Community-Ad
August's Community Spotlight Awards
