I think your issue is with the switch and not with the WLC.
port channel and its load balancing algorithm is handled from the switch, not the WLC.
You need to check your interfaces on the switch and make sure they all belong to the same port channel. The recommended load-balancing algorithm with the WLC is src-dst-ip
Amjad
Rating useful replies is more useful than saying "Thank you"
