11-11-2010 08:52 AM - edited 07-03-2021 07:24 PM
Guys,
i am trying to factory reset my location appliance from the serial. the reason for this is that i down graded it last night and am having issues.
I notice that you can clear the config once you add it to WCS but i cant do this, gives me an error that either my username is incorrect or networking issues.
Am happy to reinstall the whole thing if need be.
Please help
11-12-2010 12:17 AM
/opt/locserver/db/linux/server-end.db
Deleting this file, sets the Location appliance back to default from a database perspective (deletes any interaction that has been done through WCS).
There is also the initial config wizard :
/opt/locserver/setup/setup.sh
you can run it to reconfigure basic 2710 options.
In case of lost root password to appliance :
- Once the GRUB screen comes up, press Esc to enter the boot menu
- Press 'e' to edit
- Navigate to the line beginning with "kernel", and press 'e'
- At ehe end of the line put a space, followed by the text "init=/opt/locserver/setup/setup.sh"
- Press Enter to save this change.
- Press 'b' to begin booting
- The boot sequence will commence at the end of which the initial location appliance setup script will be run.
- The user may follow the instructions given by the script to change one or more location related parameters.
- At the end of the script, the user will be asked if they would like to reboot the machine
- Select yes, and let the machine reboot.
- Please note, that if the user only wishes to change the password, the pre-beringer recovery method will work as well.
I hope this helps.
Nicolas
don't forget to rate answers that you find useful
11-13-2010 06:13 AM
thanks for your reply.
i didnt have that file:
[root@loc-server root]# /opt/locserver/db/linux/server-end.db
-bash: /opt/locserver/db/linux/server-end.db: No such file or directory
but did have a server-eng.db that i could delete.
in the end i uninstalled the server and reinstalled which has resolved my problem (After hours of fighting with it)
thanks again for your help.
MJ
