03-26-2019 01:07 AM - edited 07-05-2021 10:07 AM
AP is not joining to the 3504 Controller. Last unsuccessful attempt reason Failed to add database entry??? Need urgent help??
Solved! Go to Solution.
03-28-2019 08:22 AM - edited 03-29-2019 12:59 AM
You are running a very old software 8.5.105.0, I suggest you upgrade first to 8.5.140.0.
Then make sure you have enabled the license on the WLC and also accepted the EULA. You can do this in the webinterface of the WLC.
Configured country is wrong (see Leos post), make sure you have configured an NTP server on the WLC.
List of regulator domains (allowed countries): https://www.cisco.com/c/dam/assets/prod/wireless/wireless-compliance-tool/index.html
[edit]
Corrected my post, because I posted the wrong information about the country.
03-26-2019 01:15 AM
Post the complete output to the following commands:
03-28-2019 03:47 AM
Hello Leo,
Please have the below output for your convenience.
WLC output:
(Cisco Controller) >show time
Time............................................. Thu Mar 28 14:16:00 2019
Timezone delta................................... 0:0
Timezone location................................
NTP Servers
NTP Polling Interval......................... 600
Index NTP Key Index NTP Server Status NTP Msg Auth Status
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.5.105.0
RTOS Version..................................... 8.5.105.0
Bootloader Version............................... 8.5.103.0
Emergency Image Version.......................... 8.5.103.0
OUI File Last Update Time........................ N/A
Build Type....................................... DATA + WPS
System Name...................................... TMTG-WLC
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.2427
Redundancy Mode.................................. Disabled
IP Address....................................... 172.16.115.5
IPv6 Address..................................... ::
Last Reset....................................... Cold reset due to PLL_DC_OK
System Up Time................................... 0 days 5 hrs 54 mins 22 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
--More-- or (q)uit
System Stats Normal Interval..................... 180
Configured Country............................... Multiple Countries : CN,IN
Operating Environment............................ Commercial (10 to 35 C)
Internal Temp Alarm Limits....................... -10 to 80 C
Internal Temperature............................. +69 C
Mgig Temp Alarm Limits........................... -10 to 78 C
Mgig Temperature................................. +54 C
External Temp Alarm Limits....................... -10 to 71 C
External Temperature............................. +47 C
Fan Status....................................... OK
Fan Speed Mode................................... Disable
State of 802.11b Network......................... Disabled
State of 802.11a Network......................... Disabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
OUI Classification Failure Count................. 0
Burned-in MAC Address............................ 6C:6C:D3:B4:5E:00
Maximum number of APs supported.................. 150
System Nas-Id....................................
--More-- or (q)uit
WLC MIC Certificate Types........................ SHA1/SHA2
Licensing Type................................... RTU
AP output:
AP-07>sh version
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
--More-- [*06/04/2018 23:04:10.2846]
[*06/04/2018 23:04:10.2846] CAPWAP State: Discovery
[*06/04/2018 23:04:10.2946] Discovery Request sent to 172.16.115.5, discovery type STATIC_CONFIG(1)
[*06/04/2018 23:04:10.2946] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
export@cisco.com.
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
heetah_CCO/label/corsica]), [wnbu-vmw-lnx-02:/san/BUILD/workspace/83MR4_Repost_C--More--
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Mon Jun 4 23:03:21 PDT 2018
ROM: Bootstrap program is U-Boot boot loader
BOOTLDR: U-Boot boot loader Version 31
AP-07 uptime is 0 days, 0 hours, 1 minutes
Last reload time : Mon Jun 4 23:03:21 UTC 2018
Last reload reason : unknown
memory. -AP1832I-C-K9 ARMv7 Processor rev 0 (v7l) with 967420/779140K bytes of --More--
Processor board ID KWC224704TN
AP Running Image : 8.3.143.0
Primary Boot Image : 8.3.143.0
Backup Boot Image : 0.0.0.0
2 Gigabit Ethernet interfaces
2 802.11 Radios
Radio FW version : c5d79906494f60ee03674c0779e5c30b
NSS FW version : NSS.AK.1.0.c10-00017-E_custC-1.67978.1
Base ethernet MAC Address : 70:18:A7:2E:45:E8
Part Number : 0-0000-00
PCA Assembly Number : 074-104313-03
PCA Revision Number : 01
PCB Serial Number : KWC224704TN
Top Assembly Part Number : 074-104313-03
Top Assembly Serial Number : KWC224704TN
Top Revision Number : A0
Product/Model Number : AIR-AP1832I-C-K9
AP-07>sh ip interface brief
Interface IP-Address Method Status Protocol Speed
wired0 172.16.115.16 static up up 1000
wifi0 unassigned unset administatively down down n/a
wifi1 unassigned unset administatively down down n/a
srcr6 unassigned unset up up n/a
[edit]
03-30-2019 04:17 AM
Thanks for suggestion and help, the problem has resolved after enabling the license on the WLC and also accepted the EULA.
Best Regards
Tonny
03-28-2019 10:42 PM
The controller is configured for China and India.
But the AP Regulatory Domain isn't for either country. So this is the reason why the AP won't join the WLC.
08-31-2019 02:26 PM - edited 08-31-2019 02:27 PM
Dear All,
I am experiencing issues in adding the 2800 series WAP to 3504 WLC receive the message Failed to add database entry?, after reading the blog I have verified the software on WAP (WALL MOUNTED) via cdp is Cisco AP Software, ap3g3-k9w8 Version: 8.2.166.0 and hopefully by upgrading to 8.5 will solve the problem.
Build Info....................................... Engineering Special
Product Version.................................. 8.5.140.0
RTOS Version..................................... 8.5.140.0
System Name...................................... LON00480WLC001
IP Address....................................... 172.26.6.139
Last Reset....................................... Soft reset due to RST_SOFT_RST write
System Up Time................................... 0 days 4 hrs 12 mins 48 secs
System Timezone Location......................... (GMT) London, Lisbon, Dublin, Edinburgh
--More-- or (q)uit
Configured Country............................... GB - United Kingdom
License is due to get activate and currently running evaluation would that be an issue?, any thoughts / input would be appreciated.
Saad
08-31-2019 04:34 PM
