918
Beginner
Fast Roaming /802.11r on WGB
Hello eveybody,
I have a mesh network with WGB as client, then now i want to enable the FT. So Is Fast roaming supported on WGB?
I found this guide:
http://www.cisco.com/en/US/products/ps6087/products_tech_note09186a0080b90500.shtml
but it doesn't explain about 802.11r FT
Thanks in advance.
Regards.
José Luis
Everyone's tags (5)
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Master
Re: Fast Roaming /802.11r on WGB
802.11r is only available on AP's that are joined to the WLC. WGB doesn't support it and will not connect to a WLAN with 802.11r enabled.
-Scott
1 REPLY 1
Highlighted
Hall of Fame Master
-Scott
Content for Community-Ad
August's Community Spotlight Awards
