11-10-2016 07:57 AM - edited 07-05-2021 06:06 AM
Dear All,
it's no fun having to replace 500 Access Points manually in Cisco Prime. Does anyone know of an efficient way how this can be done fast and easy ?
Would APIC-EM be the right choice or the REST API ?
Thanks and BR,
Thorsten
11-10-2016 05:44 PM
Hey,
By replace do you mean on the map? I believe that can only be done manually unfortunately.
Ric
11-11-2016 04:00 AM
Hi Ric,
thanks for your comment. That´s a pity. Is it possible for the other Settings to be automatically merged from the old AP to the new (AP Group, Primary WLC and so forth) ?
Cheers,
Thorsten
11-14-2016 11:16 PM
Slow reply sorry. I don't think so without some sort of scripting assisting you using the API Read/Write functionality.
11-15-2016 12:37 AM
Thanks Ric. I will have a look at the REST API and see what can be done.
