01-23-2015 11:56 AM - edited 07-05-2021 02:20 AM
Hi All,
I've upgraded the FUS to 1.9.0.0 on a few WLCs now with no apparent ill effects. The ~25-30 minute reboot time has me wondering if this is just boot BIOS improvements or does it affect the way the WLC runs in any way. I have read the release notes ( https://software.cisco.com/download/release.html?mdfid=282600534&flowid=7012&softwareid=284364857&release=1.9.0.0&relind=AVAILABLE&rellifecycle=&reltype=latest ) but still curious if anyone has heard of any performance changes, good or bad about it.
Solved! Go to Solution.
01-23-2015 01:27 PM
I have seen weird issues when the FUS was not upgraded. Things worked better after the FUS was applied. This is from my experience when I have had to troubleshoot issues.
-Scott
01-23-2015 01:27 PM
-Scott
02-20-2015 03:41 PM
Scott, do you happen to have details on the issues? Having installed dozens of WLCs I am having a heck of a time with one rollout. I'll likely start another thread on that but I am grasping at straws and wanted to see if the FUS played a part.
01-26-2015 05:46 AM
- The 25-30 minute install-time of the FUS should not be corrrelated to quality aspects of it;neitther to controller performance afterwards. It's just needed to get the correct parts of the FUS to the correct controller components. Attaching a console terminal to the controller during the FUS install process will probably give detail about what happens.
M.
01-27-2015 05:28 AM
install the FUS image to upgrade components such as the bootloader, field recovery image, FPGA/MCU, and other firmware to their latest respective versions.
