05-15-2019 08:54 AM - edited 07-05-2021 10:24 AM
Hi ,
I am deploying a guest SSID at remote location in Felxconenct mode , and trying to do L3 webauthentication but clients are not redirecting to the splash web page. WLC is 3500 model with 8.5.131 software / AP model is 38021.
While trying other authentication method (PSK) , the client is able to connect successfully and browse internet as well.
DHCP scope is configured locally on the switch, DNS is google (8.8.8.8)
is there any suggestions ?
05-15-2019 06:25 PM
Pls see following deployment guide helps you with it
Rasika
05-15-2019 10:38 PM
Hi Rasika,
Thank you for your reply !
I have already seen this guid, in my situation internal web authentication is used (WLC) so i have followed all steps except redirecting to external web server and applying pre authentication ACL. But still the client is not redirected to web authentication page.
Do i have to configure ACL to make it work ?
Hawas
05-17-2019 07:04 AM
05-21-2019 01:12 PM
Yes, You have to configure ACL and need to allow on the AP or Flexconnect Group (if you are using it).
05-21-2019 03:08 PM
Thanks Patoberli and Ravindran for reply !
virtual interface address is 2.2.2.2 and I don't use ant ACL with Flexconenct.
It works now , the problem was there was an old unmanaged AP (SOHO) broadcasting same SSID.
05-21-2019 11:40 PM
Don't use the IP 2.2.2.2. Use an IP of the range 192.0.2.0/24. As soon 2.2.2.2 uses HSTS (like 1.1.1.1 does) and the OS of the clients or browsers gets updated, they cannot connect anymore.
